Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Dyno Numbers from a set of our 195cc 23 Degree heads
Old 01-17-2006, 12:59 PM
Gunnar@Patriot's Avatar
Default Dyno Numbers from a set of our 195cc 23 Degree heads
Here are some dyno numbers from a customer who built a 350 +.030", 6.00" rods, SRP flat top pistons, Comp 230 int./236 exh. .510"/.520" 110 LSA hydraulic roller, Performer RPM air gap intake, edelbrock card, Patriot 2.02"/1.60"/64cc 195cc runners, Super Street version. Below are the numbers:
RPM Torque HP
4400 446.5 374.1
4600 448.3 392.7
4800 449.3 410.7
5000 448.2 426.7
5200 446.6 442.2
5400 443.2 455.6
5600 437.5 466.5
5800 429.6 474.4
6000 423.4 483.7
6100 420.2 488.0
Old 01-17-2006, 02:09 PM
Nightrida's Avatar
nice numbers.
Old 01-17-2006, 03:13 PM
Thank you. Forget to mention that these heads are 100% CNC ported, come with Ferrea valves, our Gold springs, ti retainers, machined locks, screw in studs and guides plate all for only $1295.00 per pair.
Old 01-17-2006, 03:52 PM
1fastWS6's Avatar
Nice Gunnar......what's the compression on that setup? About 11:1?
Old 01-17-2006, 04:44 PM
CTSV05's Avatar
Very Nice
Old 01-17-2006, 05:18 PM
Strokinit383's Avatar
Nice. Id also like to know the comp. ratio. What cam is that? Looks similar to an xe284.
Old 01-17-2006, 07:27 PM
EPP
EPP's Avatar
I have a set of these heads in stock that Gunnar loaned me to put on display in one of my showcases. I need to pay Gunnar for them, who wants to get a good deal? Bob
Old 01-18-2006, 10:54 AM
Compression was approx. 11-1. Golen engine service is using these heads on one of their crate 383 programs and is getting 510-518 hp.
Old 01-18-2006, 11:14 AM
This is a Comp Cam part # 12-432-8. Here is a link to Summit's website with the specs:
http://store.summitracing.com/defaul...=egnsearch.asp
Old 01-19-2006, 08:27 AM
1fastWS6's Avatar
When are you starting production on BBC heads? :o)
Old 01-19-2006, 08:57 AM
Have not started anything on the BBC heads yet.
Old 01-22-2006, 06:53 PM
blackz93's Avatar
What brand?
Old 01-23-2006, 10:20 AM
Originally Posted by blackz93
What brand?
These are our own castings.
Old 01-23-2006, 03:39 PM
blackz93's Avatar
So they are called Patriot Performance 195cc heads? Cool.
I was thinking AFR or something.
Old 01-23-2006, 04:17 PM
Yes sir, we call them our Patriot Classic 23 degree heads.
Old 01-23-2006, 04:48 PM
blackz93's Avatar
Cool.
Old 01-26-2006, 09:51 PM
1bdbrd's Avatar
wow! those are VERY impressive results. is there anyway you could possibly put up the actual dyno chart? i have a hard time visualizing the powerband just by looking at numbers. also i assume this is crank hp correct? im in the middle between a built ls1 and a built sbc for my 3rd gen trans am and this might be enough to push me over the top...
*EDIT* couple more questions. what intake bolt pattern do these have and are they perimeter or center bolt valve covers?
Old 01-27-2006, 12:53 PM
We will try to get a better copy of the dyno chart. The one we have a is not a good copy. We can set you up a set for center bolt and the intake pattern is for a carb intake. This is crank hp.
Old 01-27-2006, 07:08 PM
1bdbrd's Avatar
what style carb intake? theres a couple different bolt patterns for the SBC intake 86 and older and 87 and newer.(dunno if you knew that or not but i figured i would throw it in. ) it would be GREAT if they could be cast for both that way theres no limitations. also, to get a little more info out about these heads maybe you should look into becoming a sponsor at www.thirdgen.org right now most run MUCH pricier AFR 195 heads but if your heads perform nearly the same for damn near half the cost, they would be HUGE sellers! just a little fyi. also, if you really want to jump into this market, maybe a heads and cam package would be cool too. i assume you guys have access to an engine dyno to test out different cam profiles. a heads and cam setup making good power for 2k or so would sell HUGE on TGO as it takes the guesswork out.
and ya that graph would be totally awesome! if finances stay good i may pick up a set later this summer.
Old 01-31-2006, 05:37 PM
justanova's Avatar
I am doing a similar build and have been shopping for heads, these look real promising. I have much interest in seeing the dyno graph as well, or at least the power #'s in the lower rpm range.
Quick Reply: Dyno Numbers from a set of our 195cc 23 Degree heads
