Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
327 cam choice?
Old May 1, 2006 | 08:52 PM
Tan327's Avatar
Default 327 cam choice?
I need to order a cam soon for my carbed N/A 327. I'm looking for a large cam that is still streetable, something like a street/strip application. Any info at all will be a big help.
Old May 1, 2006 | 10:30 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
might want to list heads, intake, carb, trans, converter and gearing. could help a little in picking right one (or suggestions)
Derek
Old May 1, 2006 | 11:25 PM
Tan327's Avatar
Heads, intake, carb - need suggestions.
Trans - th350 or th400.
Converter - 3000-3500 stall.
Gears - I'm thinking 3.90's
I'd like to make close to 400RWHP, and maybe later push 550 on the bottle. I was going with a 454 but decided to run this small block and now I'm back to point A. Thanks for the help man.
Old May 2, 2006 | 12:13 AM
67SS&99SS's Avatar
327s love rpms, so make sure your heads flow enough to support the high revs.
Heads:
dart pro 1's
canfield
RHS Vortec Heads
AFRs
dart iron eagles
Cams:
1.XE 274 Comp Cam Hydrallic Flat Tappet 230/236
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,000 RPM
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 286
Advertised Duration: 274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.487 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.490 in.
Valve Lift with Factory Rocker Arm Ratio: 0.487 int./0.490 exh. lift
Lobe Separation (degrees): 110
2.Lunati Voodoo LUN-60103 227/233
Basic Operating RPM Range: 1,800-6,200 RPM
Intake Duration at 050 inch Lift: 227
Exhaust Duration at 050 inch Lift: 233
Duration at 050 inch Lift: 227 int./233 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.489 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.504 in.
Valve Lift with Factory Rocker Arm Ratio: 0.489 int./0.504 exh. lift
3. Offroad Z28 Cam 12364053 Camshaft Kit, Mechanical
Blueprinted replacement for factory P/N 3927140, this is an off road special camshaft, auto with 4000 converter.
Technical Notes: Basic rpm range is 4200 - 7200; and compression ratio is 11.0 - 12.5. The duration at .050 lift (intake/exhaust) is 257/269 degrees, and the valve lift is .493"/.512". Lobe centerline is 112
Old May 2, 2006 | 06:53 AM
7 Second Club
I agree on the above listings. You'll need a cam that can spin between 6500-7000 rpm to come close to 400 RWHP, plus a good set of heads as well. I'd look Victor Jr. intake and a 650/750 HP Holley. you might want to consider a solid roller camshaft as well. My 383 is making 372 hp at the wheels, and that's with Canfield heads, Vic Jr. 750 HP Holley, 3" exhaust, TH400 with a 10" 3800 stall. Might be a little lofty for 400 RWHP but can be done.
Good luck!
Derek
Old May 2, 2006 | 09:28 AM
JstALs1's Avatar
I achieved 400hp in my 327 by punching out the block .060 over previous owner blew it up with nitrous. The cam I choose was an edelbrock 234/244 @ 0.50 on a 112 lsa. To top it off I put on a set of gm fast burn aluminum race heads 2.00 intake and 1.58 exhaust with 1.6 rockers and a polished high rise intake with a demon carb. The power band is awesome and it pulls all the way to 7200 with no problems and it idles great through a th350 with a tci 3000 stall. Hope this helps a little.
Old May 2, 2006 | 07:52 PM
Tan327's Avatar
Thanks again for all of the help guys, tons of great info here. I had a family friend offer me $500 for just the block and crank earlier today, are these old 327's worth anything or is he crazy?! I'm thinking about selling it to him, so I'm open to any kind of small block setup that will put these numbers down. If you guys have any input I'd really appreciate it.
Old May 2, 2006 | 09:05 PM
7 Second Club
bare blocks can go upwards of $600-$1000 if they have casting #s matching what someone needs for a restoration, or if the block is a 4-bolt main version.
If you are looking to start from scratch, more cubes the better! I love my 383, but if I ever have the funds I'll build a 434-454 based off an aftermarket block (stronger, more material, more cubes = more power).
Good luck either way!
Derek
Old May 2, 2006 | 10:10 PM
Tan327's Avatar
I guess that makes sense. I thought about it some more and I'm just going to keep the 327, I've already got the thing apart and it's begging for a buildup. Thanks for the help, if anyone has any other info to add just send it my way.
Oh, and I've got a set of Corvette 350HP heads, are these worth using?
