building a 496 need some pointers/thoughts
thanks
nick
The L29 heads are good heads, but not from a high performance standpoint. They are bigger than the peanut port (truck) BBC heads but not as large as the traditional large oval ports (781,049,215,063). They have a high swirl small combustion chamber to help keep compression up. They also have a non-adjustable valvetrain that would need to be converted over to adjustable if you use much more than a stock cam. Porting and chamber work may do more harm than good with these heads (screw with the swirl design).
You may be better off finding an early set of closed chamber 396 heads (702,206,215,063s) that will flow better, keep your compression up (without use of a large flow impeding dome), and not require conversion to an adjustable valvetrain.
A hydraulic or hydraulic roller cam in the 240@.050 range is a good choice and I would aim for around 550-600 lift and 110 l/s. This would give a broad powerband and not lope very bad but still have a good sound.
The oval port heads are definitely the way to go for a heavy street car under 500ci that wants to make all its power before 6500rpm. A mildly built 454 with oval ports can get a 3500lb car into the high 10s in the 1/4 once you get it hooking all that torque.
Caleb
If you do keep the L29 heads and a cam as suggested, you will have a total torque monster that will be through by 4800 rpm. You definitely need an older set of large oval ports, there is about a 30cc difference in the intake runner size between the two styles of heads. Also, unless you have some major suspension upgrades, this engine will make gobs of unusable torque at a very low rpm, so you may want to step the cam up in duration just a little bit. Keeping it around 245-250@.050 for a hydraulic cam would be a good start for 10:1 compression. If you decide to go solid flat tappet or mechanical roller add about 8* to the .050 duration to be ~ equivalent. You should still have in excess of 500lb/ft by 3000rpm stepping the cam up to this size and make all your power by 6500rpm.
I am using a solid flat tappet set-up in my 496 with Schubeck ceramic lifters and my cam is 255/263 @.050 110 l/s and 612/630 lift. I chose this cam working with a cam designer to match my 10.5:1 compression and make 600hp/650lb/ft with large oval ports with a little work. Since I bought these, I got a screaming deal on a set of AFR 335s with 114cc chambers and jesel shaft mount rocker arms. The heads are a little big but the have good velocity, so I don't think they will hurt me at all. New goal is 700hp with the same set-up.
Caleb
nick
