Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Big Block Options...info needed
Old Sep 16, 2006 | 09:55 PM
PowerPlant's Avatar
Default Big Block Options...info needed
I'm trying to search for all available options so any and all info is needed. I am pretty new to engines and options so I am looking for as much tech and reading as possible.
I am in the market for a big block chevy engine with 800-1000 hp, pump gas, reliable, and FUEL INJECTED. Those are my guidlines, I am open to anything else except NOS.
What are my options? I am trying to find the best all around deal possible. Custom builders, crates, etc.
Old Sep 17, 2006 | 12:59 AM
Stroked SBC's Avatar
Reher Morrison, Sonny Leonard, Steve Schmidt, Jon Kaase are probably the four biggest dogs on the block with YEARS of experience backing them up. And I feel like I'm forgetting one more, maybe someone else will chime in.
Old Sep 19, 2006 | 09:23 PM
PowerPlant's Avatar
anybody else??
Old Sep 19, 2006 | 10:13 PM
Cali99SS's Avatar
Try Nelsonracingengines.com. They got some amazing stuff
Old Sep 20, 2006 | 11:46 AM
LS69TA's Avatar
And not cheap either
Old Sep 20, 2006 | 11:53 AM
Firechikn's Avatar
To get 800-1000 hp NA on pump gas will be expensive. I'd bet big cubes and some awsome heads. As stated, going with a big name builder will be your best bet. I hope you have plenty of $$$$$.
Old Sep 20, 2006 | 08:08 PM
PowerPlant's Avatar
Are there no other viable options than big name builders? I was looking into the ramjet 502 with supercharger. With a friendly discount I think I'm looking at about $13K with close to 800 (or more) hp. I have found many 800hp carb engines for 5-7K. So I was hoping there would be a Fuel Injected option out there somewhere with comparable hp. That way I could supercharge that and be close to, if not well above, 1000hp for 13K or less. Anybody?
Old Sep 25, 2006 | 08:17 PM
PowerPlant's Avatar
ttt..
Old Sep 25, 2006 | 08:48 PM
MrMiracle's Avatar
Do you want strictly multi-point fuel injection (where each cylinder gets its own injector) or are you willing to go with throttle body injection (an EFI that simply replaces the carb).
Multi point is certainly discreet and very efficient, with no risk of intake puddling. Throttle body is far simpler, and allows you to use intakes and superchargers that are designed for carbeuration. It also allows you to maintain a classic look. Neither option is very inexpensive.
You could start with a 454 HO short block ($3300) or a 502 short block ($4200). Both have nice, low compression for boost applications, and have all-forged rotating assemblies. Add AFR heads (which come nicely polished) for $2000 to $3000. Weiland supercharger kit for $2700. You'll probably need a pair of throttle body injectors. That'll run for at least $2000. And of course none of this includes all the funny extras like distributor, gaskets, fasteners, etc.
1000 horses from anything doesn't come cheap. If you don't want to spend an arm and a leg off the bat, you could just get a 454 HO crate engine for $4800. It has the same low compression, all-forged assembly as the short block. Add a temporary carb, or throttle body injection for now. Supe it up later when you're willing to spend more.
Old Sep 27, 2006 | 09:02 PM
rocket22's Avatar
A EFI 632 will get right around 800 if you get brave on the comp.My old combo in my pro streeter was 632 with brodix big dukes and efi with a F.A.S.T system.It made 802hp
Old Sep 28, 2006 | 06:30 PM
MerlinPro's Avatar
Collections Removal
PowerPlant,
Not trying to sell you anything 'cause we don't do EFI and that's what you want. Appreciate, however if you'd share info on this comment :" I have found many 800hp carb engines for 5-7K. "
Whose engines are these? Are they warranteed and dynoed? Are they used? Firechikn is very correct in his advice.
Our 632/800 is $17K. (pump gas) Our 540/825 ($16.5K) and 632/900 ($19.2K) are C-14 engines.
Where did you find these $5-7K engines?
Old Sep 28, 2006 | 09:30 PM
rocket22's Avatar
to fuel inject a motor figure about 5k.depending on intake,and ecm.I built my own 632 and had 19k in it.my current engine in it is efi 710 had there 25k in it.
Old Oct 8, 2006 | 07:47 PM
PowerPlant's Avatar
1.any other options?
2. Is 800HP, fuel injected, feasable for say $12-13K or less?
Old Oct 9, 2006 | 07:59 PM
motormonkey's Avatar
You wont find fi na 1000hp for less than 30,000. It takes more than just the motor. Fi that can support that hp level is expensive in its self. The only 800 hp motor for 7000. has a 400 shot of nitrous option that is sold separetly to get that number i bet.
