Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
SBCvsLS1??
Old Dec 28, 2006 | 11:56 AM
  #121
xdamxincx's Avatar
Originally Posted by KHShapiro
Again i agree with you.
This wasnt suposta be about discrediting either or but it turned that way.
I did however think was was mainly about build costs.
So what would it take to build a 600 FWHP Gen1 and a 600FWHP Gen3
Yes there have been some posts with links but would anyone like to do the research and find parts deals and post parts pricing for each
Lets then compare compression ratio ,Cams and street manners.
We could even drop the power lvl down or up is someone has an idea.
1 Saying you already have core engines complete with stock rotating(already in need of a rebuild)
2 no core (no blocks)
you cant start a build like that ur already giving the ls a lead .. how much would a stock core ls1 vs a sbc cost to begin with .. u cant just begin with two stock cores.. did santa just drop off some stock cores ? no ... start off with prices of both stock cores and go from there. but either way .. there are toooooo many variables in such a build to even be accurate.. like for instance if your talking building a n/a motor then thats not the norm.. hardly anyone is building n/a motors ..
Old Dec 28, 2006 | 03:22 PM
  #122
KHShapiro's Avatar
Yes a core LS can be thousands more than a core Gen1
would it work if it is only blocks that are on hand?
this is also why #2 says no cores meaning no blocks.
i am just trying to start a base so a comparison can be made.
We have to start somewhere with a build. No used peices either , has to be something new, if you arent figuring on using a stock core.
Old Dec 28, 2006 | 03:54 PM
  #123
s10mods's Avatar
Originally Posted by Subliminal Hit
not sure how much power you are looking for but if you ever want to go fi then a sbc would be your best bet because once you get up to about 800whp on a fi ls1 you start pushing water because they only have 4 bolts per cylinder
anyone see this yet? 6 bolts/cyl. up to 2500 Hp seems like gm is making more and more peformance stuff for the gen III's.
http://www.gmperformanceparts.com/En...6454&engCat=ls
I was hardcore Gen I for the longest time, and now I am about to build my first Gen III. Cant wait.
Old Dec 28, 2006 | 09:06 PM
  #124
topend's Avatar
when i was looking for a new engine setup for my car. I came up with two choices BBC or SBC. i wanted a powerful and reliable NA motor. I didnt want to worry about dropping a sleeve or lifting heads or running over my crankshaft. There is way more aftermarket parts available for the SBC than the LSx.
So what would it take to build a 600 FWHP Gen1 and a 600FWHP Gen3, Lets then compare compression ratio ,Cams and street manners.
Both would have the same street manners fuel injection or not. the 600HP sbc would be cheaper.
Old Dec 28, 2006 | 11:54 PM
  #125
JAY ROD's Avatar
I would like to see a sbc vs lsx showdown to 600fwhp.I bet it could be done for the same money and I bet the sbc spits a rod or crank bearing after the 3rd dyno pull.
Old Dec 29, 2006 | 02:18 AM
  #126
xdamxincx's Avatar
a friend of mine just built him a ls2.. iron block,eagle crank,eagle h beam rods, mahle coated pistons,dart heads, comp nitrous cam, 1 7/8 headers etc etc... says he is estimating 500-550 fwhp..
not sure how much he has in everything but i can check
Old Dec 29, 2006 | 11:03 AM
  #127
KHShapiro's Avatar
there is no way they would have the same street ablity, esp if it was EFI.
Old Dec 29, 2006 | 12:08 PM
  #128
blown454ss's Avatar
im trying to come in here and start **** with anyone, but your on drugs if you truelly think that.
Old Dec 29, 2006 | 12:13 PM
  #129
KHShapiro's Avatar
i think he is making that statement if it was with stock crank and or rods
Old Dec 30, 2006 | 10:22 AM
  #130
topend's Avatar
explain how the SBC and LSx engines making the same power would have different street manners.
Old Dec 30, 2006 | 11:38 AM
  #131
KHShapiro's Avatar
another member already quoted this, but as a builder and anyone else who has built SBC's already knows this.
http://www.chevyhiperformance.com/t...ine_dyno_tests/
you have to go alot further with the Gen1 and it isnt street friendly, when compared to an ls series.
That link also gives you a nice idea on a build up.
Old Dec 30, 2006 | 05:12 PM
  #132
JAY ROD's Avatar
I have some explaining to do.Any and I mean this,Any small block we had either built for us or built by us never kept it's bearings.That is why I am such a hater of the sbc.Now don't go saying I am a shitty engine builder or say the guy who we paid huge money to build our engines is a shitty engine builder because I have seen with my experience around cars a ton of knocking small blocks.I beat on my ls1 like it owes me money and it hasn't skipped a beat on a stock bottem end with 175000kms spinning 6800rpm.
Old Dec 30, 2006 | 08:36 PM
  #133
topend's Avatar
Check out this thread there are a few guys with SBC that run nines on pump gas and street driven.
http://www.thirdgen.org/techboard/or...ml#post3171926
Old Dec 30, 2006 | 09:34 PM
  #134
KHShapiro's Avatar
with power adders, and again just because you run it on the street doesnt mean its streetable, or as it goes what street? Notice any of the compression ratios, or cam specs?Sure they can run on pump gas, but do you really want to, more importantly would you want to even drive it on the street. One more time, are we talking about E.T's or engines.
Old Jan 10, 2007 | 07:59 PM
  #135
Notime383's Avatar
I don't know about SBC and those bearing complaints? Especially when compared to the "ultra quiet LSX" ??? I 've put together 1000+HP SBC that don't have bearing problems after 6 years over 100 passes of Nitrous injection stock block, cast crank, running 10.30's in a street driven 3500lb camaro! Hmmmm... Also have one going mid 8 's in the same car about 50 passes later no problems. That of course doesn't mean they don't damage bearings, just that I don't think it's a common thing. LSX motors I think are great, but SBC has nothing to envy when it comes to staying together and making some power!
Old Jan 10, 2007 | 09:27 PM
  #136
Quickin's Avatar
NRE just did over 100 dyno runs with their new 454ci sbc, took the engine apart and it looked like they never started the damn thing. Oh, and it was their 2,300 fwhp 454 sbc TT. Yup, 2,300 FWHP, daily driver engine.
Good luck with an LSx type engine at half that power. And the W2W 352ci engine is over $100,000, so it doesn't count and it doesn't make near 2,300 fwhp anyway.
LSx type engines (T, TT, SC'ed) are blowing up all over the place on a daily basis at 700 RWHP+.
Old Jan 11, 2007 | 12:37 AM
  #137
JAY ROD's Avatar
Bullshit on a 2300 h.p daily driven motor.wtf does it run on,gun powder?
Old Jan 11, 2007 | 06:32 AM
  #138
Genesis_26317's Avatar
Originally Posted by G&HRacing
If you want power with the least amount of money, forget SBC or LSX, build a BBC.
Kudos
What the hell is this going in anyway, I am having trouble finding it in the thread (I'm drunk and insane).
I can't tell if it is going in a SBC original Corvette or a 4th gen F-Body.
If it goes into the old school Corvette get a BBC and tear up the streets on the weekends and park it 90% of the time.
If it goes into the 4th gen stick with a stock type set-up installation is a freakin' bitch and a half. LT1-LS1 or SBC (empty bay) to BBC.
Old Jan 11, 2007 | 08:14 AM
  #139
MADMAN's Avatar
LS1Tech Sponsor
Well while you guys bench race I will be at the track racing. My sbc will make all 3 qualifying passes and hopefully go all 4 elimination rounds(If I dont get beat.) For some damn reason out of the 35 cars that show up regularly NONE of them are LS1 based engines.
Down the road in a few years there might be some LS1 stuff out racing competitively but right now the technology isnt there.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jan 11, 2007 | 09:59 AM
  #140
427's Avatar
427
The "W2W 352 engine" is mine and it is not 100,000. It is not near half that. What it is right now is the fastest LS on the planet. Not sure why you insist on posting mis information about us.
Kurt
