Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
BBC sheetmetal intake kit
Old Nov 22, 2006 | 01:07 PM
LS69TA's Avatar
Default BBC sheetmetal intake kit
Anybody know of a place that sells sheetmetal intake kits for a big block Chevy?
Old Nov 22, 2006 | 01:18 PM
JUICED96Z
Guest
Posts: n/a
Pretty sure Wilson can
http://www.wilsonmanifolds.com/
There is some pics there that show the quality, well worth the money.
BILLET BANK SHEET METAL MANIFOLDS $3,000
Wilson Manifolds has applied the same technology used in our one-off custom designed billet bank sheet metal racing manifolds to our new line of Limited Production Billet Bank Sheet Metal Manifolds. By producing these select manifolds on a limited production basis, we are able to provide a much more affordable manifold that fits the most popular cylinder heads and produces excellent overall performance in many high performance and racing applications, particularly with larger displacement and/or high RPM engines. They also look great on street rods and show cars and are designed to fit under stock hoods. These manifolds are ready to bolt on out of the box and are designed to accept Wilson Manifolds high flow throttle bodies and ultra high flow fuel rails as well as Nitrous Pro Flow direct port nitrous systems and manifold pressure relief valves. These designs were developed using our state of the art solid modeling software, and each manifold’s cylinder banks (flanges and runners with integral injector bosses, stanchions, and direct port nozzle bosses) are machined from billet 6061-T6 aluminum on our simultaneous 5-axis CNC machining center. Each manifold is then precision fixtured and heli-arc welded for a perfect fit and maximum structural integrity. This production method allows for optimum runner to runner and manifold to manifold consistency in terms of both geometry and performance.
Old Nov 22, 2006 | 07:56 PM
rocket22's Avatar
Hogan Manifolds,I'm not sure they do a kit thou.
Old Nov 22, 2006 | 09:09 PM
mrdragster1970's Avatar
6 & 8 Second Club
Never used them, but Weinle motorsports has an ad in N.D.
Old Nov 23, 2006 | 09:08 AM
LS69TA's Avatar
I found the Weinle site, their weld-it-yourself kit looks like it's $1000.
Old Nov 23, 2006 | 09:33 AM
68maro's Avatar
7 Second Club / STF Veteran
here is good info http://forums.godragracing.com/viewtopic.php?t=42798 . also i'd do a profiler cast intake. they seem to be making the same power with out the harmonics for half the cost. also get on racingjunk and look for one used.
Old Nov 24, 2006 | 12:02 PM
6 & 8 Second Club
We used a profiler intake on my profiler motor. Many others have been having good luck with the cast intake also. Have they made intakes for stock valve angle heads??
I've only seen them on the big chief style heads.
Old Nov 24, 2006 | 08:59 PM
68maro's Avatar
yep they make them for conventional heads too. in single and dual 4 configurations
