Machine shop questions
I have heard its like $15 a hole to bore it. Engine will be tore down to the block.
Please seperate prices also.
I will not have the chance to call around untill after the first of the year.
All our work is done in a HAAS 4-axis CNC machining center.
Southside.
Off of the Southport rd exit on 65.
some people dont like cutting on cranks and will just get a new crank for a bit more $
a set of studs for the mains. AND dont forget the 14% tax on that which brings us to $1140. F*&(ken insane!!!
hot tanked
magnafluxed
remove all old freeze plugs and bearing
put new freeze plugs and cam bearings
smooth lifter valley/ enlarge drain hole
hone lifter bores
1/2 fill (block filler)
zero decked
bored & hone cyl walls
clearances for 383
but for just a regular 350 build that doesnt need all the little things i have for a race motor (block fill, smoothed lifter valley, clearance for stroker crank)can be had for about 500 all said and done
