pics of my 355 build up
i am finnaly putting it back together for the second time after my machinest didnt put the rear cam bearing in far enough and toasted a bunch of stuff , these are some pics of the first build up.
350 4bolt main block .030 over decked and lined honed
355 balanced eagle rotating assembly cast crank forged rods and hyp pistons flat top
Brodix Ik200 aluminum heads 200 cc intake runners 2.02 intake 1.60 ex 64cc
edelbrock performer rpm airgap fully ported
speed demon 750 vacume secondaries
comp cams extreem magnum 501-510 lift 440-446 duration 110 lsa
comp cams 1.61 promagnum fully roller rockers
comp cams magnum hardend pushrods
mallory distributor and wires
ARP main bolts, rod bolts, head bolts, intake bolts, header bolts
http://i123.photobucket.com/albums/o...o/DSC01689.jpg
http://i123.photobucket.com/albums/o...o/DSC01673.jpg
http://i123.photobucket.com/albums/o...o/DSC01674.jpg
http://i123.photobucket.com/albums/o...o/DSC01690.jpg
http://i123.photobucket.com/albums/o...o/DSC01692.jpg
http://i123.photobucket.com/albums/o...o/DSC01717.jpg
http://i123.photobucket.com/albums/o...o/DSC01715.jpg
http://i123.photobucket.com/albums/o...o/DSC01716.jpg
http://i123.photobucket.com/albums/o...o/DSC01723.jpg
http://i123.photobucket.com/albums/o...o/DSC01679.jpg
http://i123.photobucket.com/albums/o...o/DSC01682.jpg
http://i123.photobucket.com/albums/o...o/DSC01719.jpg
http://i123.photobucket.com/albums/o...o/DSC01721.jpg
http://i123.photobucket.com/albums/o...o/DSC01720.jpg
pic of my truck its goin in
http://i123.photobucket.com/albums/o...sjimsss007.jpg
http://i123.photobucket.com/albums/o...sjimsss008.jpg
tell me what ya think
2500 stall seems a bit on the low side for that cam. If you are looking for mid/high 12s your combo will have to be spot on. On street tires im 12.7 with much less weight than you and a similar motor.
Make sure you double check that The machine shop put the cam bearings in the right spot, and check all your clearences, my machinest put my rear cam bearing in wrong and toasted my cam and main and rod bearings and he didnt stand behind it, hope everything goes together good,
Originally Posted by My01SSCamaro
What goodies you got in yours?
Originally Posted by njkid
its decked bored and the mains was laser lined. small little cam, but im going with a bigger one i just gotta order up a crank which ill do tommrow. ill post pics up soon
what kind of heads ya ganna run?
nothing really special. there gonna be close to stockers. my brother and i are gonna build them. I'm building my engine right next to his so what his not gonna use, i am going to use if i can. what size valves do u have?
they are 2.02 1.60, you and pick a set of vortecs for about 100-200 and get them rebuilt vortecs have 170cc intake runners versus about 150cc for some stockers, mine are 200cc, you know what size cam your ganna go with? make sure you get the right springs for the cam.
Originally Posted by Red97Z
badass engine! I gotta ask though...are you gonna spray it
ide rather not have to break anything motor wise for awhile after having to pull it out of my truck and dissamble it and then reassemble it and put it back in, kind of tiring,
