cheap performance heads
Last edited by 1997bird; Jan 18, 2007 at 08:38 PM. Reason: Read non-sponsor policy!!
mmk...where do you get 5 angle valve job..all mine are 4's...i dont even do 3...
Top cut/seat/bottom cut/bowl cut IE: 30/45/65/75 Im guessing the transition angle from top cut to the chamber..but other then that theres no use for a 5 angle or more valve job.
hmm you were talking about the dart sportsmans...those arent TO bad, but out of the choices here the platinums would be best unless you want an aluminum head..
Thanks for supporting the sponsors on this site
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Only downside to Vortec's is you'll have to buy self aligning roller rockers, and a vortec style manifold and only able to run .480" lift(unless you buy the Scoggin Dickey modified heads).
I'd buy Vortecs, easy 40hp.
