Attn. engine guys...
Here's what I'm looking at so far, if you have any suggestions please post them. Thats why I'm asking you guys, I'm a rookie when it comes to building engines.I'm looking into a forged 383, I've always heard good things about 383's and I plan on spraying eventually. I priced an eagle rotating assembly. It's a balanced, forged kit. H beam rods, forged 4340 crank, with -7.00cc. dome pistons.
I already have a lunati bracket master II cam in the 350. I had planned to reuse it. Its a hydraulic flat tappet, 292/292 duration, .480/.480 lift. I was told that was the biggest I could go with stock pistons. It's power rated for 2000-6000rpm. I'm guessing I can go bigger with the new pistons?
Also, I'm looking at a set of AFR heads, from what I've read the 195cc's and the 210cc's are about what I should be looking at for a 383. What do you guys suggest?
2 bolt block converted to splayed 4 bolt, half fill with block filler,eagle 4340 3.75" stroker crank, eagle 4340 5.7" h-beam rods, SRP .040" forged flat tops, (10.8:1CR) afr 210 race heads, 5 angle valve job, bullet solid roller cam 265/276 @.050 .630/.635" lift 110 LSA, Pete Jackson "noisy" gear drive, vrictor jr intake, fully prepped Holley 950 HP carb, 200 shot direct port, 100 shot plate, msd crank trigger and dist. msd digital 7+
now keep in mind, mine is a track car, but with a less aggressive cam, and a smaller carb this thing could run the streets on pump gas all day.
Here is a link on an engine we built for a customer and we used the AFR's on this engine but we have built a few 383's with some well prepared 906 Vortec heads and have had the same results with torque and Horse power.
http://www.chevelles.com/forums/show...highlight=DYNO
-4 bolt 350 milled for 383 kit
-4340 forged eagle crank with 3.75" stroke
- .30 over forged aluminum eagle pistons with -5cc flat tops
-forged steel 4340 H beam rods 5.7"
-internally balanced
-11.8:1 compression
-VIC jr intake
-Lunati voodoo cam 241 intake/249exhaust dur@.50" 525/546 lift 2,500-6,600rpm
Not sure on this, It's just a suggestion. I checked on the 4-7 swap but all the ones i found make power from 4000 up. I don't know if I want to rev the thing to 7 grand, or maybe that would be better, hell i don't know.
-Afr 210cc aluminum heads, 76cc combustion chambers,
And of course ARP bolts and studs for the heads
for the rest of the drivetrain I was thinkin along the lines of 3200 stall, th350, and either 3.73s or 4.10s (possibly a th400 but I already have the th350)
The lunati voodoo cam says its rated around 2,500-6,600. with a 3000 stall, would that still be somewhat streetable.
OR!! This ones way out of left field. Eagle offers a forged kit with a 6" rod, but the pistons have a -16cc inverted dome, which quotes 10.4:1 compression.
