Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Vortec 350ci..11's?? 350+rwhp?? Lets hear it.
Old 01-30-2007, 08:41 PM
  #81
moge11's Avatar
Stunningman, I posted TWO....STRAIGHT PUMP GAS.
Go to www.BadAssNovas.com. This guy and Malibu2slow of www.nastyz28.com both run 93-94 octane.
Badassnovas is DrivingWFO at nastyz28.com
Dirt Reynolds of nastyz28 also had a pump gas combo, but do to poor quench had ot SOMETIMES add a splash of race gas in the heat of the summer.
Old 01-30-2007, 09:09 PM
  #82
The stunningman's Avatar
They are both splashing race gas. 94 turbo blue is a race fuel.
Do your math on what if takes to truly come up with 11 to 1 then add in the fact you have to start pulling timing early as it is with vortecs.
There are some tricks to slow the burn and make them less detonation prone but we aren't on that here.
Old 01-31-2007, 01:37 AM
  #83
1997bird's Avatar
Originally Posted by The stunningman
Anyone can come on and say.." I build race engines and a company like Erson wants to hire me." Does that make it true.
If you want to see if I am truely a shop or not I am leaving a independant company's name for you to check out. Look up Dunn & Bradstreet in a search engine to get their link. Then you can look up my business name and verify that I am a legitiment business owner. I had to have an account set up with them in order for me to become a wholeseller for the Mr. Gasket Co. family of parts. I leave this thread in the hands of the veiwers for their sake.
Shane
Precision System's LLC
Old 01-31-2007, 04:44 PM
  #84
moge11's Avatar
I used to get Super Premium it was called?? 94octane at Citgo. So its NOT a race fuel.
Old 01-31-2007, 05:22 PM
  #85
chevydad's Avatar
says sunoco 94/turbo blue in his description i'm guessing a mix of pump gas and race gas.
http://www.badassnovas.com/BadAssNova.jsp
not that it means anything to any of you. i'm running close to 10:1 with my motor and still run 87 octane.
Old 01-31-2007, 09:14 PM
  #86
Read the label DA.
http://www.cosbyoil.com/turboblue.html
Old 02-01-2007, 05:52 PM
  #87
moge11's Avatar
Citgo has 94 octane and Sunoco 94 octane. NOT race fuels. They are unleaded "REGULAR" gas....DH.
Old 02-02-2007, 06:20 PM
  #88
niceroc's Avatar
good luck pullign 1.6x short times with the t-5, the best i have seen with a t-5 is 1.7x's and that was pushing it, i toasted my t-5 with a bolt on 305 with no powershifting, but i did beat the crap out of it, 1.6x's will be very difficult no matter what with a stick, and id use somehtign a lil more heavy duty then a CFDF cltuch
Old 02-12-2007, 10:15 PM
  #89
buttermantoast's Avatar
84 El Camino, 3600lbs. TH350, 383 with summit iron vortec heads, lunati cam, Holley 750 Carb, M/T ET streets, 3.23 gears, 2400 stall, 13.2 1/4 mile, 1.9 60ft first time at track ever. lol, nothing special but it made me happy.
Old 02-13-2007, 08:30 AM
  #90
chevydad's Avatar
i bet theres more in it. mine liked 33degrees total timing.how big is your cam?
i am happy with mine as well. but i'm moving on to a 02 6.0 motor now. so this one is for sale. 900bucks
mine is a 83 chevy truck 3750lbs. th350 350ci with gm vortec heads, stock 94 lt1 cam, carter 750 carb, 3.42 gears, 3500 stall, 13.5 1/4mile 1.9 60ft. that was with both hoosier QTP's and winter retreads. tested back to back.
Old 02-13-2007, 08:14 PM
  #91
.512 lift with 1.6 rockers. 292 advert. duration, 108 lsa. any suggestions on getting in the 12's, don't have any income right now, between jobs.
Old 02-13-2007, 11:07 PM
  #92
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Wow, after reading this 5 pages of this garbage I noted probably two posts of useful information, good job.
Old 02-14-2007, 07:56 PM
  #93
yeah, go away
Old 03-13-2007, 10:20 PM
  #94
BadAssNovas.com's Avatar
Just to clear up the confusion:
When I made motor-only passes, I was running 93 or 94 Sunoco pump-gas. Sometimes I ran 93 from Sheetz. I did add some Turbo Blue for making nitrous passes though. I wanted to try running 91 or 92, but never got around to trying it
I sold my Vortec top-end and have a new setup for this season, but I can tell you guys anything you want to know about my old setup. I'm here to help
Quick Reply: Vortec 350ci..11's?? 350+rwhp?? Lets hear it.
