carb stumble...any ideas?
hey everyone,
i just installed a 750 holley dp today, and it seems to be a little off. everytime i hit the gas pretty hard (half throttle or more) it cuts out for a half second then takes off. i can ease into full throttle with no problems, but when i just step on it even a little it stumbles everytime. it does this at EVERY rpm, not just idle. is it the jets? lean, or rich? it has 71s primary and 80s secondary. i don't have a clue of its a/f ratio. could it be something else with the carb? i really don't know what it is. it did it when it was cold, and at running temp. ~160deg. any help would be greatly appreciated, and i could offer more details if you need. i hope i can get this worked out!! thanks.
-dave
-dave
i don't wanna sound stupid, but how would i go about it? a bigger squirter? adjust the pump cam? or the spring? i'm kinda lost sorry.
There's probably some slack in the linkage. Try to adjust that out first. As soon as the blade is cracking you want the squirter there and starting to shoot fuel into the front venturii.
Once that is done, set the float levels in both bowls and reset the idle mixtures screws. How are you doing those? That should help a whole, whole lot. If it still has stumble to it increasing the squirter would be a good idea. You change it by adding the next larger size, or better yet pick up a few spares and a set of precision drill bits. That way, you can make your own. That's what I used to do.
Also, if you bought it used, change the power valves and then verify you have the stock jets in it. Those will be your best starting point.
Post back up, and I'll help you if you have anything else.
Ben T.
Ben T.
thanks man, i'll try doing what you said next time i'm home, probably next weekend. i'll make sure there's no slack in the linkage, then set the level in the float bowls. also, how do i know when the idle mixture is good?
Originally Posted by smokin2002
you can check your plugs, thats the best poor mans wide band out there.
Ben T.
hey everyone,
-dave
-dave
If that doesn’t do it go to a bigger squirter, but 9 times out of 10 the cam will do it.
I used to have the same problem. It could be a little different for your application, but i advanced my initial timing 1-2 degrees and it solved my problem. My motor was a fresh build too, so if youre timing was already fine then i wouldnt mess with it.
What size power valve do you have for your primary and secondaries?
Did you check your float bowl levels to make sure there at the fill plug?
Heres what im running on my 850 double pumper w/ dual metering blocks and it runs just fine. Not to rich (from plug changes)
Primary Secondary
Power valve 4.5 6.5
Jets 78 88
White accelerator pump cam.
My idle mixture screws are turned 2-1/4 turns out both sides on primary.
Hope this helps somewhat.
Primary Secondary
Power valve 4.5 6.5
Jets 78 88
thanks guys for all the input! i am up at school right now, but i'll be heading back home this weekend. i'm gonna try everything you guys said, and i'll keep you updated. any more suggestions would be greatly appreciated. i hope i can get it running snappy by sunday
I was always told a good starting point on a SBC was to turn the screws all the way in, and then 3 HALF turns out (while the engines off).
Hope this helps, if you need further explanation of this, lemme know.
