Selling 4340 406 Chevy shortblock new!
My loss is your gain! 408 Chevy shortblock with Eagle Competition 4340 Rotating assembly, Stef Aluminum oil pan, ATI 7" Balancer, SFI Flexplate, Edelbrock Aluminum Timing cover, 3.75 4340 eagle crank, H-beam 5.7" rods ARP bolts, SRP Forged Flat top pistons with Swain coated skirts and tops! Clevite H series Swain coated bearings, Cloyes Hex A Just Timing Chain, Cam Motion 252/258 @.050" street roller with 4 7 cyl swap, Comp Cams Endurex roller lifters, Steel tool nitrous pins, Speed pro File fit rings (Gapped for NOS/Street use), Mellings HV HP Pump, Block is 511 casting 4 bolt with ARP studs .040" over and has .200" thickness around all cylinders! Block has Hard Block fill on lower part of water jackets 1" below water pump hole because it is intended for street use! Block also has several coolant mods! You can't build this for 5K! Your basically getting the block for free! Completely balanced and assembled! Just throw a good topend on it and make a streetable 500-650HP! This short will hold 700-800HP easily! Holds constant 60psi of oil pressure with primer tool! All parts are new except block and dyno time on lifters! I rather not ship, but can! Figure about $200 avg from NY to CA FedEx! I will meet person in NY CT NJ PA area for pick-up! $3500! (917)-642-5116.I have tons of pics e-mail me: notime383@hotmail.com
