What block for 540?
505" is the bigest, on a 9.8 I've seen that lastest more than a few pass'. I don't trust going more than .100-.110 over on a stock block. I've gone .105 several times, no problems.
Big bore block is well worth it, if you can afford it. A short deck can go 582" safely with a big bore block. I know, I've done it.
If u r looking for a good rotating assembly, I have a set up for a 555 with very few passes on it.
Lunati Pro Billet 4.25 crank
JE gas ported custom pistons
Manley Pro Mod rods
All good stuff, get a Bowtie or a Dart Block and u will be in good shape
Just throwing it out there for u
Dart Big M= 240 lbs
Merlin III=260 lbs
Now Merlin does have a block that has a 11.625 deck height and it only weighs 297 lbs, still a ridiculous claim of 100-150lbs heavier even for that block. What issues do the current merlin blocks have? I just had to say something, because that bogus claim could sway someones decision and spread even more wrong information.
A 632 has to use a tall deck block, which is a 10.2 deck height due to the 4.75 stroke on the crank..
Derek
