Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Cam doesn't lope?
Old Aug 4, 2007 | 04:43 PM
articz28's Avatar
Default Cam doesn't lope?
Just this motor together for a friend.
355, eagle crank, rods, speed pro 10:1 pistons,Dart Pro V1 215cc with 2.05 intake 1.60 exhaust, Comp XE 240/246 @.050 .507/510 lift., Summit brand 1.6 Roller rockers. Edlebrock Performer RPM intake and 750 carb.
The car just doesn't have a nice lope to it. It hits hard but just not a good lope to it. I am not concerned as the car runs strong but can't figure out why it idle's so smooth. Any Suggestions?
Old Aug 4, 2007 | 06:19 PM
SLawson86's Avatar
you didnt list the LSA. depends on that, and there's your "lope"
Old Aug 5, 2007 | 08:02 AM
smokin2002's Avatar
x2 LSA
Old Aug 5, 2007 | 02:00 PM
ZONES89RS's Avatar
In-Zane Moderator
**** that, that bastard should lope olmost no matter what,
Old Aug 6, 2007 | 09:14 AM
JAY ROD's Avatar
That should lope like crazy,what is your idle at?
Old Aug 6, 2007 | 10:17 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
What's your idle RPM?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Aug 6, 2007 | 02:47 PM
67rsss's Avatar
What idle? What timing? Manifold vacuum? What exhaust system? Can we get a video with sound to hear what you mean by no lope? Lots of people have difference definitions of lopey. Carb is a bit big for the application, and the intake is a dual plane, which should help you acheive a smoother, lower idle speed. Look at setting the idle down around 700 it it will run there, and you should be able to get a lopey sound and feel. Be careful in setting up your carb. With the design of the intake, you won't have the best off idle performance if you do not get the accelerator pump and idle circuit set decently. Use your vacuum advance if you can.
Old Aug 6, 2007 | 04:48 PM
ZONES89RS's Avatar
In-Zane Moderator
That duration should beat the ground @ 1000 rpm, somthing is wrong!!!
Old Aug 6, 2007 | 05:03 PM
thecorrectformula's Avatar
LSA has a large part. 112 lopes a hell of a lot harder than 114 and so on. List the LSA.
Old Aug 6, 2007 | 05:18 PM
AutoRoc's Avatar
Wheres the timing at? Advance or locked? Mufflers really smooth things out.
If you want it to sound bad, build it bad. hehe A single plane intake would be fun to try on a good dyno day. It should peak HP in the 6200+ range and might want the single. Goodluck!
Old Aug 7, 2007 | 06:37 PM
articz28's Avatar
I will have to get my friend to get the cam card and check the LSA. The idle is set at 900 RPM. I will get other info to yall as soon as I can, guy let his other "buddy" mess with the car so I have no idea where everything is set now so will get back to yall soon.
Old Aug 7, 2007 | 08:14 PM
67rsss's Avatar
You should be able to get a lower idle speed than that, are you running an automatic?
Old Aug 7, 2007 | 08:37 PM
articz28's Avatar
yes auto with a 3000 stall,Th350 shift kit, 3:73's
Old Aug 7, 2007 | 11:18 PM
jester1's Avatar
should be ground on a 110
that cam doesnt really have a ratical lope to it. Add cats and cheesy exhaust and it cleans up the lope. You may be able to get it down to 800 rpm idle.
tune tune tune its all in the tune
