Budget 383 Head
Im lookin for at least a 200cc runner and 265 cfm.
I was looking at the patriot heads
http://www.patriot-performance.com/w...05238&DID=1225
But I was wondering about maybe some ported vortecs but im new to SBC, known the reverse flow heads well but not to hip on the older ones, anyone else have a better recommendation?
Im looking for just around 400 crank hp from a 383, it will pretty much see track only and I dont plan on spinning it past 6K.
Not flaming, just do it right if your gonna do it.
If not using AFR 195cc eliminators, You will need at least a 210cc runner. This needs to be a 10second car.
If using the Patriots, use at least the 215cc runner, maybe the 225cc depending on Compression and cam choice. But regardless the 215cc head will make for a killer combo regardless.
Good luck, I will help you with your head and cam choices you'd like, just need to know your goals and budget.
I dont want a 10 sec car I want an 11 sec car. Plus there will be spray on top.
I dont want a solid roller or AFRs. This is on a budget.
I could care less about whos outrunning me. Im in college and on a budget. I want 11s and if it happens to run that on motor than the spray will just go in later on..
And if I run the AFRs and a solid roller, Ill need a tronger bottom end and right now Im gettin a smokin deal on a 383 kit with a nodular crank, 5140 rods, and forged pistons.
If i went patriot I was plannin on the 225cc chamber and its gonna be 10.8 to 1.
The car will be COMPLETELY STRIPPED.
And with only 400hp and even with spray a decnt 302 or 347 will wax your *** and you'll like a clown who wasted his time.
Why do I care who beats me I want to run 11s initially. If its not enough Ill throw on a solid roller and heads later on down the road and be in the 10s with spray.
It doesnt take alot of horsepower to maker a lightweight notch go fast.
Have you lost your mind, have you seen any 302, 306, 331, and 347 times lately. They dont dyno worth a damn. The 347 are okay but the rest are ***.
What year is the block? Is it a factory roller? If its a factroy roller engine then you could throw in a decent hydraulic roller cam and be in business. if you want some help with a combination, just hit me up with a PM. have fun building your abomination!
Thats whats ******* retarded...
You will have a faster car if you kept a 350ci with a good set of heads n cam with a matched carb
Putting on WEAK heads on a bigger cube motor, is only going to make it a low RPM STUMP........
That why you see so many extermly slow stroker cars, because they think big stroke=more power.....when heads play a big roll in this
Will sell you a set of 291 casting 1.94/1.50 valve, fresh valve job, camel humps for $200.
He would get spanked by H/C/I 302's all the time if he use double humps.
I finally found an old popular hot rodding and they did 657 hp for like 5K. It seems right in my price range and what Im wanting so im just going to follow there build.
306 ford..as cast canfield 220 2.02 1.60=11.00 1/4mi 3020*lbs
427 ford..cnc port canfield 220+ 2.08 1.60=6.30 1/8 mi 2900*lbs
406 sbc..as cast canfield 220ish 2.08 1.60=6.50 1/8 mi 3500*lbs
less than $1000 a pair assembled as cast
best heads for the money in my opinion*by far
