help me out guys..
help me out guys..
I know someone here has to know something about this swap im trying to put a chevy 350 into a 1972 cutlass the mounts dont line up so i was wondering if anyone knew what mounts to use or who can make some mounts for that kind of swap i dont want to weld anything
any help would be appreciated.
thanks,
luis
thanks,
luis
The frames are the same for all of the A bodies. You will have to get the frame side engine mounts for a Chevelle of that year to do it. The holes should be there already from the factory on the crossmember for every breed of GM, if not, just drill them out. After that, it should all pretty much be a direct swap!
