help me kill a pos 305 that wont die
Other attempts to kill this thing that failed were running in 1st gear bouncing off the rev limiter for 40 miles, nothing.
Going about 60 mph, neutral foot to the floor then reverse, it just stalled turned the key and it started right back up.
OT slightly but I used to drive a POS toyota, 1992 I think. You could run it up to 80mph and put it in 1st but a safety would keep it from downshifting and over revving BUT I figured out when you turn the key off it WILL go into 1st. And um make some really weird noises and never run again.
Drain the oil and add brake fluid. It will die and when the guy checks he will find nothing wrong with it. If he checks and finds water, sand and **** in it, you and your friend will have it good with him.
#34
easy to do. Add adid to it. Can be bought at any local store. Let it sit for the night and the next day you will be pulling the motor...
EDIT read someone elses post about that lol
#35
Trust me the acid works, just don't be the one who drives it after you put it in. I put a pint into six quarts of oil and it ran fine when parked. I started it in the morning, sounded like there were no bearings in it.
I did this to an old work truck and I was at the shop a few hours after they got it in, they said they have no idea what happened, only thing we found was the oil smelled burnt, but they drained it into an huge can with other used oil so there went their chance of an oil analysis.
#38
#40
Too bad you can't get the oil pan off, sure would be fun to loosen up some rod bolts and give it hell.
I know a guy who has killed 2 motors by leaving a rag in the intake, that would be kind of obvious though
