Output guess of SBC build.
Damn, i started looking for a vic jr yesterday. My car is a stick and will have 3.73 gears, right now it is 3300 or so, maybe less honstly, i still need to remove interior but i will be replacig it with light weight carpet. I still dont know what else i am going to remove(front and rear bumper).
I would still go with what I said. On the 408 it will ROCK!...Use a big solid roller in the 250/260 range on the 408ci. It will FLY!...with close to 11.8:1 or so.
What is the highest i might be able to get away with on the 408 on 93 octane? 11.8 with a 108 LSA to bleed off some cylinder pressure? I am wondering what the 11 to 1 will be like with the 112 LSA in the 383, i am sure id be screwed if it was cast iron heads but the aluminum is still pushing it i think.
I want to but till i get the 95 Z done with a LS1 swap i dont wanna be daily driving a solid roller, i have a HUGE solid roller that would make the most outta theese heads but DAMN i couldnt make it idle for the street, i think the dual plane intake and the 2 1/2 Y pipe into 3 inch I will keep some better low end TQ till i swap to a 3 inch setup and a vic jr(pro products knock off prolly).
I cannot wait to see what it will dyno and run in the 1/4, i be a H/C LS1 will be no problem
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Well, as i said, its what i have, i will deffinatly try to do a dyno and track comarison, i am just sure it is gona want the larger stuff to make the heads do what they were cast to do, i am just hoping for low 7s in the 1/8th before a intake and larger exhaust swap.
#32
Yea, it was the only decently priced pistons i could find and i hadnt ordered rods before i ordered the pistons. I think this thing is going to see 6500 RPM easily witht he dual plane, i need to buy a chip for the MSD 6AL, i have so much more in this motor than the last one i am not going ot be surprised if i make 100 more HP than before, the old engine was held back by smaller heads, cam, headers and HEI vs the new engine will be full MSD ignition, i dont know if the T5 will live to tell this time around but i have said that before, stock clutches and radials go a long way
