Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
its alive! solid roller stroker
Old Jun 9, 2008 | 01:54 PM
bluebeast's Avatar
well when i have been driving it i always put it in neuteral at redlights or stop signs and then lightly put back into gear..... doing that for a few weeks should have been ok until the new converter wouldnt you say? have a TCI 2,000 stall in it right now and putting a yank 4,000 in a few weeks
Old Jun 9, 2008 | 02:00 PM
slow95z's Avatar
it won't hurt it, thats acually what i had to do and give mine some gas even in nuetral where it was starving for fuel and air until i got my new carb.
Old Jun 10, 2008 | 02:56 AM
MrOverkill's Avatar
Originally Posted by slow95z
no, too small of a carb. i had a vac. secondary carb. and it was dieing at idle. put the 750d/p on and jetted it and had no more problems. my stall is supposed to be around 2700-3000 so i could drive in town without burning up the trans.
I drive cars in traffic with 5000+ converters on a regular basis, run a big cooler with a fan and you'll be fine.
BTW Jet size really has no effect on idle and low speed operation as they are on a different circuit in the metering blocks. So you had some other issue going on with your other carb
And yes bluebeast the looser converter will greatly improve the way it idles in gear....
Old Jun 10, 2008 | 11:49 AM
slow95z's Avatar
yes a vac secondary to begin with and went to a d/p for enough fuel to idle. then to run like i wanted it needed jetting. im not a rookie to carbs, i just started playing with f/i engines.
