need head input.
i found these online and wanted your opionion
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=003
please recommend and keep in mind i dont wanna have to spend a ton on just the heads there are other parts that i would like to get as well!!
"Will the LT1 intake fit Vortec heads?
No, it will not fit. The intake mating flange is too narrow to cover the tall ports that the Vortec head uses. Here's a cutaway picture http://www.lt1intake.com/images/vortec1.jpg with a standard SBC intake mated to Fastburn heads. Fastburn heads are drilled with both standard SBC and Vortec bolt patterns.
The LT4 intake will not fit Vortec heads either. This is due to the Vortec bolt pattern being way too high on the head for the intake. The LT4 intake can be adapted to Fastburn heads because they are drilled for both standard and Vortec bolt patterns. So an LT4 intake would still require a bolt pattern change to std gen1. Some port matching on the LT4 intake will be required when using Fastburn heads."
