383 with 11.3 CR for weekends or..?
ok Im about to finish my project its 92 Z28 with 383ci 5.7" rods,flat tops with 2 valve reliefs,11.3:1 CR,cooper head gasket,Edelbrock 200cc E-tec heads,Edelbrock air gap,750cfm holley double pump,Comp cam 236/242 520"/540" with 1.5 on 110LSA,Hedman LT,Magna flow cat back,3.73,700R4 with shift kit and clutchs and some other few stuff can my question is with that set up will my camaro will be for weekends only or it can be a daily drive car? usualy I dont go out that much in my camaro and Im worried if I go out with that set up I will face tempreture problems and I really HATE those problems maybe in everyweek I will put less than 15 miles on the camaro is it fine to be driven with that CR?
the octane in my country is 95 or 93 i guess is that enough? I will be using the stock aluminum radiator and the stock fans that comes in 92 Z28's I might switch to single large fan
In-Zane Moderator
Well, i had a 383 with a bigger cam, bigger heads, same compression and stock radiator with a 112 LSA, i had no issues at all driving it all the time. I had one upside to you, a standard trans, made my brakes work pretty well. You will be happy with it and i even had a 383 with cast iron heads and that same cam shaft and it did verry well.
well thats good to hear because I was thinking of changing the head gasket to a thicker one and before two days ago I was like why I dont run the engine with the same gasket and everything the previous owner was using the engine and the tempreture was 180 without any thermostat so I guess I will be fine with 160 thermostat and high cfm dual fans
My setup is similar to that with iron heads and I can run fine on pump gas in cool temps and sometimes in the heat. I do have a large radiator and my electric fan is always on, like said above quench is important though.
capn smokey I dont think I will open the heads to check the quench the previous owner of the engine just installed everything without doing any machine work on the heads
