Need tools to fly-cut pistons- rent/borrow
Im needing the tools to do this. Im not asking for opinions on why this should not be done, etc.etc.etc.....So if you have the tools I would appreciate the use of them. If you dont have them or know someone who does and can't help me out, keep your thoughs and comments about doing this to yourself.
![Locked ...](https://ls1tech.com/forums/images/smilies/lockd.gif)
Don't do it. ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
High lift is worthless on stock heads and you need to re-balance the rotating assembly anyways once you remove weight anywhere.
Pay the machine shop to do it.
Sorry DJ, I would NEVER flycut myself, I had to save a friend from peril. At least I said it-I can sleep better at night. ~Joshua
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Originally Posted by BadAzz96Z28
Im needing the tools to do this. Im not asking for opinions on why this should not be done, etc.etc.etc.....So if you have the tools I would appreciate the use of them. If you dont have them or know someone who does and can't help me out, keep your thoughs and comments about doing this to yourself. ![Locked ...](https://ls1tech.com/forums/images/smilies/lockd.gif)
Contact Mike @ Vengeance Racing & Development he has a tool for doing this. At least last spring he did ... he showed it to me one day while I was at the shop.
I sent Ron a message....no reply
I needed to talk with him yesterday myself and he did not answer his cell or the office number.. I didn't try to reach Mike..Ron might have had something to attend too outside the biz...he is usually is good about getting back with people who try and contact him...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Just an e-mail from work
Wouldn't it be pretty amazing, if this caught on, all over the country...?
"GOOD MORNING, WELCOME TO THE UNITED STATES"
"Press "1" if you speak English." "Press '2' to disconnect until you can.
![Offtopic](https://ls1tech.com/forums/images/smilies3/offtopic.gif)
I'll vote for the law or contribute to the fund that gets that put into effect...
Originally Posted by ba78ta
if you haven't bought the cam.. go for a smaller duration big lift cam... then you won't have to fly cut.. for example.. the patrick g cam
Also here is another saying from the AJC
”I have to pass a urine test to stay employed. So it’s only fair that people collecting welfare should have to pass a similar test to collect.”
F*CK all you on welfare you lazy bastards
![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
Also me and my girlfreind were at a restraunt and one of the waitresses was telling another one that she was going to have to cut back on her hours at work otherwise there not gonna give her her welfare check. You can all guess what type of person this was
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
ls-who....thanks for the offer but I have a friend that can do it w/ them out of the car as well. I am not wanting to tear the engine apart for this. I am not planning on having the rotating assembly ballanced after doing this. I drive the car maybe 3k a year and ballancing increases bearing life. Im not worried about that due to the low miles of the engine, and the fact that it will be replaced with a 4xx cid LSX in the future.
Originally Posted by 00TurboT/A
Him fly cutting the pistons has nothing to do with his cam size. His cam is fine. The heads he's wanting to get for the car are milled and would have to fly cut the pistons to work with his cam.
Also me and my girlfreind were at a restraunt and one of the waitresses was telling another one that she was going to have to cut back on her hours at work otherwise there not gonna give her her welfare check. You can all guess what type of person this was![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
and I don't seem to understand all the **** you posted beneath that.. but whatev
he is using the same cam he has been running for a year and he is just milling the heads. he does not want to change the cam. also i think he said if u dont have any help keep your comments to yourself.
