Southern Members A regional forum for all our down South members.
Need Help With Lid
Old Jan 19, 2007 | 08:33 PM
Bklynstanger's Avatar
Default Need Help With Lid
My MTI Lid just came in. On my stock lid, there was a wire connected into the lid; however, the MTI lid does not have this connection. What do I do?
Old Jan 19, 2007 | 08:41 PM
bene's Avatar
Trunion King
Are you talking about the A.I.R. system? The tube that is connected to your stock lid? If you are talking about this, just get a small breather and zip tie it to somewhere where is secured.
Old Jan 19, 2007 | 08:42 PM
So it doesn't need to be connected into the MTI Lid?
Old Jan 19, 2007 | 08:50 PM
HUNTER02SS's Avatar
No not the tube he said a "wire". that goes to the factory lid.You need to drill a hole in your new one and take the grommet out of the old one and install it.I think it is your inlet air temp sensor.
Old Jan 19, 2007 | 08:55 PM
bene's Avatar
Trunion King
If he's talking about the IAT sensor, all you have to do is take the grommet/sensor out of your stock lid and put it into you MTI lid.
Old Jan 19, 2007 | 10:03 PM
Guys, I am talking about the IAT sensor and rubber grommet. I'm assuming that the only option is to drill a hole into the new lid and slip in the IAT sensor and rubber grommet. Correct?
Old Jan 19, 2007 | 11:17 PM
bene's Avatar
Trunion King
If you don't have a hole, I guess so. My MTI lid came w/ a hole though... weird.
Old Jan 21, 2007 | 11:36 AM
spazzyfry123's Avatar
Yeah, my SLP lid came with a hole for it, too. Might want to check with MTI to see if you got some bogus lid.
Old Jan 21, 2007 | 03:49 PM
02SSLE's Avatar
yeah mine had hole already
Old Jan 21, 2007 | 04:42 PM
HUNTER02SS's Avatar
No hole provided, Drill and install it yourself. It will take you 5 minute's>
Old Jan 21, 2007 | 06:05 PM
02 WS6 TA's Avatar
Interesting, I've never seen one without an IAT provision, either. But, what Chris said above.
Old Jan 22, 2007 | 09:27 AM
I called MTI over the weekend, they said that the new lids do not have the holes for the IAT sensor and rubber grommet. I drilled a hole and used the IAT sensor and rubber grommet from the stock lid.
