Southern Members A regional forum for all our down South members.
Rear U Joint ?
Old Feb 26, 2007 | 05:54 PM
Jimmyz's Avatar
Question Rear U Joint ?
If I broke this today while leaving a stop light pretty hard, how would I know it?
Car made a loud POP back there, I heard a pinging of some sort on the pavement and then it started vibrating under medium acceleration. Car still moves but somethings weird. I looked under the car and didn't see anything broken but haven't been able to get UNDER the car for a look. Does this sound like a U joint or strap holding it to the yoke broke off?
Old Feb 26, 2007 | 08:19 PM
SLowETz's Avatar
Jim.... dude.... take your wore out old fat *** UNDER the car and answer your own question
Old Feb 26, 2007 | 08:24 PM
HUNTER02SS's Avatar
LMFAO!!!! If you don't see anything yet keep driving it and I bet you will shortly!
When that happened to mine it didn't take long for the rear to go and then it took the tranny with it!
Old Feb 26, 2007 | 08:41 PM
Jimmyz's Avatar
I looked and can't tell...unless its just sorta broke. Something is for sure wrong though.
Old Feb 26, 2007 | 08:55 PM
SLowETz's Avatar
If the straps are still bolted to the joint, and there is no visual damage, my guess is a broken ring gear tooth.
Jack up the rear end under the diff. Put it in neutral and spin the wheels by hand. If it's a broken gear, you'll hear it or feel it when the missing tooth/teeth make contact with the pinion gear-
Better yet.... pull the cover and have a look. You needed to change the fluid anyway
Old Feb 26, 2007 | 08:57 PM
Jimmyz's Avatar
That wouldn't be so good for me chief.
Old Feb 26, 2007 | 09:28 PM
BLKWS6's Avatar
hey Jimmy....the village called....they want their Idiot back
Old Feb 27, 2007 | 05:59 AM
BadAzz96Z28's Avatar
When I broke my U joint.....My D/S feel out of the rear yolk about a couple of feet after it snapped. Thank god for the Spohn T/A with the D/S loop, that could have been ugly.....
When I broke a tooth on my ring gear it just made a pop, and then was always making a clunking noise. It didnt really have a bad vibration- just more noise
Old Feb 27, 2007 | 07:19 AM
Jimmyz's Avatar
Okay, did all your suggestions. No noise or feeling spinning the wheels. DS is in the yoke but I see no straps on the joint. Is that possible?
Old Feb 27, 2007 | 07:55 AM
SLowETz's Avatar
Yeah it's possible. Prolly not enough DS end play between the rear yoke and trans for it to come out. Sometimes it's a tight fit until you unload the rear suspension.
You got lucky.
Put new straps on it a have a nice day-
Old Feb 27, 2007 | 08:18 AM
the joint is pressed in the d/s. There is no strap on the joint at the d/s- just some clips keeping the caps from coming off. At the yolk there is a strap on each side of the u-joint cap holding it to the yolk. Is both straps/caps and the bolts still in place?
Old Feb 27, 2007 | 01:46 PM
Jimmyz's Avatar
I see no straps at all. Caps are in place...maybe I thru a a DS weight?...I have no clue what to think at this point. Taking it to a shop...is the only option for this "village idiot".
Thanks guyz!
Old Feb 27, 2007 | 02:03 PM
SLowETz's Avatar
Jim...... are the U straps that hold the U-joint to the pinion yoke on or not?
Old Feb 27, 2007 | 02:45 PM
BLKWS6's Avatar
lol....we still like ya Jimmy....
Old Feb 27, 2007 | 02:50 PM
i like tater tots
Old Feb 27, 2007 | 03:03 PM
Jimmyz's Avatar
Angry
I don't see dick for straps. just took it for a ride and maybe something else is broken. Sucker vibrates/and BUZZES back there in 1st gear under lite acceleration. Never got out of 1st turned around, put it in the garage.
Old Feb 28, 2007 | 05:56 AM
where you live at? Is this your DD or weekend car? I may be able to stop by and take a look at it and see what we can come up with.
Old Feb 28, 2007 | 07:37 AM
Jimmyz's Avatar
I live in Cobb county near 120 (upper roswell rd) and OLD Canton Rd. Weekender type vehicle.
Old Feb 28, 2007 | 09:35 AM
slt200mph's Avatar
i like tater tots
With me its a toss up between the tater tots and the chillie cheese fries..
Old Feb 28, 2007 | 10:10 AM
Bring on the heavy TP and air freshener with the chilli cheese fries
By Brett Foote | 2026-06-04 05:00:17
