AIS Rear Trunk Mount Water Methanol Injection Group Buy - Ends Feb. 29th
Old 02-22-2008, 11:18 AM
AIS
AIS's Avatar
Default AIS Rear Trunk Mount Water Methanol Injection Group Buy - Ends Feb. 29th
Till Feb. 29th 2008, we will be running a GP on all rear trunk mount water methanol injection systems and stainless steel hose upgrade kits. Each water methanol injection system comes fully assembled, pre-wired and tested. Additionally, all systems are now shipping with our new black anodized aluminum tank straps as shown in the images below. Furthermore, each system comes complete with everything you need right down to the grounding screw and rubber grommets. The only thing needed by you is the tools and the fluid.
To join the GP you will need to call in and place your order once we have 6 or more members signed up. As each order is placed we will hold the orders and not process the credit cards until minimum 6 members sign up. As we receive each order we will post them on the thread for everyone to verify. As soon as we have six orders, orders will process and ship.
Let us know if you have any other questions or how we can help.
AIS Stage 1 Trunk Mount Water Methanol Injection System
Custom molded 1.5 gallon water/alcohol fuel cell
Instant response right when you need it
150 psi pump compatible with 100% alcohol
Adjustable boost activated switch
Trunk mounted keeping weight of the front end
Pre-assembled, pre-wired and tested - ready to go
Normal Price $369.99
Group Purchase Price $309.99
AIS Stage 2 Progressive Trunk Mount Water Methanol Injection System
100% digital processor for lighting fast response
Quick, easy to use adjustment *****
Normal Price $599.99
Group Purchase Price $519.99
AIS Stainless Steel Single Nozzle Hose Assembly
16 ft -4 Stainless steel hose
100% compatible with methanol
Fully assembled - swivel fittings already installed
Blue anodized AN fittings
Includes adapter NPT to AN adapter fittings
Normal Price $109.99
Group Purchase Price $79.99
AIS Stainless Steel Dual Nozzle Hose Assembly
Two individual 9" -4 stainless steel hose assemblies
Blue anodized AN -4 tee fitting
Blue anodized AN hose fittings
Two nickel plated nozzle holders
Two blue anodized NPT to AN adapter fittings
Normal Price $59.99
Group Purchase Price $39.99
Old 02-22-2008, 06:49 PM
SSilverSSurfer's Avatar
so after buying stage 1 or 2 what else is required to run it? where in the trunk does it mount?
Old 02-22-2008, 07:36 PM
GTO1_OHIO's Avatar
What are the dimensions of the fuel cell?
Old 02-23-2008, 09:38 AM
AIS
AIS's Avatar
L - 12"
W - 8.5"
H - 7.5"
Old 02-23-2008, 09:39 AM
AIS
AIS's Avatar
System comes complete with everything minus the tools to install it and the fluid. Where you mount it is your choice. Each vehicle is different and each customer has his or her own preferences.
Old 02-23-2008, 07:44 PM
Vertigo's Avatar
Would this work on a 99 GTP? Looking to downsize the pulley and don't want to worry about KR. I really do not know anything about these systems but i am interested. PM me.
Thanks!
Old 02-24-2008, 02:07 PM
AIS
AIS's Avatar
Thanks!
Absolutely. We've worked with many customers who owned the Pontiac GTP. These Eaton M90 superchargers will develop 220-230 degree air discharge temperatures with only 7-8 psi. By spraying just before the inlet of the throttle body we have lowered these temperatures by 100-110 degree's. On our website is a customers Thunder Bird which is running a non-intercooled Eaton M112. With no changes to boost and only the addition of a Stage 1 water methanol injection system and custom tuning, this customer picked up 50 horsepower at the tires.
Be sure to check out www.Magnacharger.com as they have a video on their home page of a LS2 Magnacharged engine in which the ran our Stage 2 system on. While this is a different engine entirely, it is the same principle and style supercharger. Our Stage 2 system was used primarily as an octane enhancer for this build as they were running California 91 octane pump gas with this engine. However, additional charge air cooling helped contribute to the performance of the engine.
Old 02-25-2008, 10:04 AM
dkrowner's Avatar
i pm u,so call me if u can
Old 02-25-2008, 02:27 PM
AIS
AIS's Avatar
"dkrowner" has just joined in on the group buy. We need four more orders for everyone envolved to receive the group buy discount.
Give us a call at 1.801.447.2559 for questions or technical help choosing which system is right for your application.
Old 02-25-2008, 10:29 PM
hashtagBMW
Speed Density's Avatar
That is by far the coolest meth kit ive seen!
Good luck with the GP guys!
Old 02-26-2008, 04:36 PM
94greencamaro's Avatar
I will be calling you guys tommorrow and probably putting an order in
Old 02-27-2008, 11:30 AM
chucklaw's Avatar
How many more people do we need?
Old 02-27-2008, 11:31 AM
AIS
AIS's Avatar
Sounds great. This is a great deal for everyone who's been wanting one of our trunk mount systems. With your order we will need 3 more orders to reach the 6 required orders we need to make this happen.
Here's a link to more information about the benefits of our rear trunk mount systems vs the standard fender/firewall mount systems.
http://www.alcoholinjectionsystems.c...icle_info.html
Additionally, here's a picture showing members everything that is included with our Stage 2 system and how it arrives. Our Stage 1 systems are completely identical with the exception they do not come with the progressive controller as shown in the picture. Stage 1 systems come with a adjustable boost switch which is mounted to the head of the pump.
Let us know if you have any other questions.
Old 02-27-2008, 11:32 AM
AIS
AIS's Avatar
We've received lots of emails and phone calls. We need just 4 more orders.
Old 02-27-2008, 05:07 PM
sciff5's Avatar
How long does one tank of h2o/methanol last? And is windshield washer fluid really what you are supposed to use?
Old 02-27-2008, 05:32 PM
chucklaw's Avatar
I can't answer the tank question, but I use to have an 03 GTI with an upgraded turbo and a water/meth kit. I ran windshield washer fluid in it. Most windshield washer fluids are up to 40% Methanol and 59% water. Although most contain some glycol and detergent(less than 1%). Try to find one that indicates "contains methanol" and is rated to (at least) -20ºf.
Old 02-27-2008, 05:57 PM
chucklaw's Avatar
Here is something else that I found on the web to help you determine the amount of Methanol in windshield wiper fluid...
+20 F Washer Fluid - Contains approximately 7% Methanol
0 F Washer Fluid - Contains approximately 23% Methanol
-10 F Washer Fluid - Contains approximately 28% Methanol
-20 F Washer Fluid - Contains approximately 35% Methanol
-25 F Washer Fluid - Contains approximately 38% Methanol
-50 F Washer Fluid - Contains approximately 62% Methanol
Old 02-27-2008, 06:06 PM
called and put in my order today.....so there should only need to be 3 more orders
Old 02-27-2008, 06:23 PM
hashtagBMW
Ya'll should think about extending the GP a few more days!
Tony.
Old 02-27-2008, 07:16 PM
AIS
AIS's Avatar
It really depends on the application. For example if nitrous users are only activating the water methanol during a nitrous run, then our 1.5 gallon container will literally last for months.
For NA and supercharged applications it comes down to how much driving they are doing. How big of a shot they are running. What their system settings are on the water methanol injection and so many more. In the end, a typically 600 horsepower supercharged or NA application will get about 3-4 weeks of use out of one trunk mount container.
Yes you can use windshield wiper fluid. You will find many are using this because it's affordable, easy for many to locate where they live and already contains a mix of methanol and water. Now when your shopping for a windshield wiper fluid you want to first look for a temperature rating of at least negative -20 degree's. Depending on which state you live in, you may or may not have this available. Warm states such as Florida, Arizona, Texas generally don't have the right type of windshield wiper fluid available.
Now before you buy the wiper fluid and pour it into your container always check to make sure it contains methanol. If it does it will be listed on the container. Additionally, some brands contain 1-2% glycol. We have had countless customers and our selfs run this fluid without any issues. If you don't want to use a wiper fluid which contains glycol simply look up the MSDS sheet on it and check it yourself to see if it contains glycol.
Other sources for pure methanol are local speed shops and hobby shops which sell alcohol powered remote control airplanes and cars. You can also run denatured alcohol which you can purchase from Home Depot or Lowes. This is essentially ethanol with a little methanol in it to keep people from drinking it. Imagine that right!
Let me know if you have any other questions or how we can help.
Quick Reply: AIS Rear Trunk Mount Water Methanol Injection Group Buy - Ends Feb. 29th
