Even Deeper Discounts on Certain In Stock Short-Blocks @ TSP!
Here's a handful of in stock short-blocks that we're marking down until the end of the year to clear the shelves and make room for new combos! All of these prices include 12 quarts of the Joe Gibbs break-in oil, the crate and cradle to fully enclose and protect the short-block in transit, and the shipping charges themselves to the lower 48 states! No hidden fees or extras here, just great deals!
For those needing the conversion kits to run the Gen4 engine in your Gen3 equipped car, you can add this kit for $300!
402ci Aluminum LS2 - $3800 total!
Eagle 24X crank
Eagle H-beams w/ ARP2000 Bolts
Wiseco -3cc FT 4.005" Bore Pistons with PlasmaMoly Ring Set
Clevite H Bearings
GM Main Cap Bolts
Eagle 24X crank
Wiseco -3cc FT 4.005" Bore Pistons with Plasma/Napier Ring Set
Clevite H Bearings
GM Main Cap Bolts
427ci Aluminum LS7 - $5200 total!
Eagle 24X crank - ESP Armor Coated
Wiseco -32cc Pistons with PlasmaMoly Ring Set
Clevite H Bearings
GM Main Cap Bolts
Eagle 24X crank
Clevite H Bearings
GM Main Cap Bolts
Eagle 24X crank
Clevite H Bearings
GM Main Cap Bolts
Clevite H Bearings
GM Main Cap Bolts
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
__________________
I don't have any 347's in stock currently
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
__________________
__________________
The top 418 with the steel top ring set should handle 300 or so of nitrous....assuming you've got the proper fuel supply and octane, tune, top end, etc!
__________________
Updated!
__________________
The 4cc 418's would put you about 12.0:1 with the .053" gasket and those heads.
Is yours going to be a nasty NA build? What are your plans?
__________________
Also, it's worth reminding everyone that ANY stroker short-block gets the free shipping deal as long as it's ordered before the new year, even if it is a new build and will not ship until after the new year!
__________________
It could probably handle a 300+ shot w/ the right tune-up in it. I have seen the same components go over 1000 RWHP on a turbo setup as well. Even with the factory mains! These parts can take a good amount of abuse before you would ever run into a parts related failure.
Jon
Jon
