January LS1TECH Rewards Program - Win $100!
Old 01-05-2004, 02:09 PM
  #81
00silverz28's Avatar
I plan on installing all the stuff I have bought over the last couple months.....subframes, linelock, ftra....etc. Plus I want to get a nice cam and ls6 intake bought and installed before the summer.
Steve
00silverz28 is offline
Old 01-05-2004, 03:11 PM
  #82
OBXMarine's Avatar
My New Years resolution would be to get a 3/4 ton tranny, transfer case, and 6.0l so I can go all out (SC and 3000 stall in the immediate future) without the worries of blowing the tranny.
OBXMarine is offline
  #83
NHRATA01's Avatar
My main goal is to get a 12 bolt and slicks, finish the suspension work, and hopefully crack an 11.99 before the season is out.
My 2nd goal is to finally get a more snow-worthy vehicle for next winter, as my '89 Firebird doesn't work very well!
NHRATA01 is offline
Old 01-05-2004, 04:25 PM
  #84
BADSZ28's Avatar
My automotive resolution is to get a SPEC stage III clutch and learn to get consistant at the track.
BADSZ28 is offline
Old 01-05-2004, 04:51 PM
  #85
Scalpel's Avatar
I plan to get the Darton MID block to pimp out the Cannibal
Scalpel is offline
Old 01-05-2004, 04:53 PM
  #86
equandt's Avatar
My new year's resolution is to get my cam installed in the Z. I would like my '99 Tahoe to see 120K miles this year with only oil changes and regular maintenance. I need to teach my Tahoe to stop chasing deer, last year it got one (ouch).
equandt is offline
Old 01-05-2004, 05:26 PM
  #87
OvalHunter's Avatar
The goal is to get into the 11's. I have the folowing winter projects planned: 4.10 gears and girdle, tires (wide sticky ones),line lock to heat them up, torque arm & LCA's W/brackets to prevent hop on the launch. 8pt cage so I can keep running after I hit the goal.
I'm hitting 114 mph now, so the ET should follow with a little better traction.
OvalHunter is offline
Old 01-05-2004, 08:26 PM
  #88
The Guy in MY 99TA's Avatar
My new years resolution was to put the trans am into the 10's with stock internals, then add headers, cam, a direct port nitrous set up and just race her for a while. I need thet 100 bucks so I can do some suspension work also! I also have plans to add several APPEARANCE mods to her this year. IF I joing the marines I plan on buying a Hyabusa. Other than that I'de like to get my engine for my 68 Camaro outa the machine shop.
Josh S.
The Guy in MY 99TA is offline
Old 01-05-2004, 08:44 PM
  #89
BraemerZ28's Avatar
Default January rewards reply
My plans for the upcoming year are to work on finding a set of long-tubes for the T/A and see if I can figure out where that damn rattle is coming from under the rear bumper!
BraemerZ28 is offline
Old 01-05-2004, 09:01 PM
  #90
02Hawk502's Avatar
My plans are to fix my beater truck (1977 GMC 1/2 ton), coat the Hawk with wax, get the suspension going on it, and try to keep as many miles off of it as possible.
02Hawk502 is offline
Old 01-06-2004, 03:18 AM
  #91
Special K '01 WS6's Avatar
12 Bolt, 4.30's, and a set of Pro Stars ... and I'll be on my way to possibly some high 10's or maybe just some easy 11's
Special K '01 WS6 is offline
Old 01-06-2004, 10:09 AM
  #92
Smoke T/A's Avatar
I hope to cut some 1.3-1.4 60 ft's and propel my car down in to the mid to low 6's in the 1/8th.
Smoke T/A is offline
Old 01-06-2004, 10:16 AM
  #93
02 SOM WS6's Avatar
Since I burned up my transmission at the strip last time I went and now have it rebuilt, I just want to go and get kicked off the track for running way into the 11's with no roll bar.
Les
02 SOM WS6 is offline
Old 01-06-2004, 10:20 AM
  #94
2002WS6_MN6's Avatar
This year I would like to sell my 1998 GTP and replace it with a 1998 Suburban 6.5 Diesel.
For my Trans Am I need to install my Kooks headers sitting in my garage!
2002WS6_MN6 is offline
Old 01-06-2004, 01:01 PM
  #95
Kens_02SS's Avatar
I'm hoping and praying to resolve my issue on what heads to get for my baby plus tune it and then off to the track
Kens_02SS is offline
Old 01-06-2004, 08:18 PM
  #96
2QuikTA's Avatar
My automotive resolution for this year is to save as much $$$ as I can for my new Ws6 next year after having to sell mine this last year. A $100 gift certificate would sure help start the modding!
2QuikTA is offline
Old 01-07-2004, 01:42 AM
  #97
slmdLS1's Avatar
Plans are to finish swapping the motor into the truck, slam it 4/6, nice 17" Boyds, Stg2 Heads and a Cam, maybe spray into 11's by summer.
slmdLS1 is offline
Old 01-07-2004, 02:48 AM
  #98
BlackWS602's Avatar
My goal for this year is to finally get the funds for my Comp 921 valvesprings and ****** the LS1 cam only record
BlackWS602 is offline
Old 01-07-2004, 03:27 AM
  #99
PongoX11's Avatar
Got a TR224 in my car over the summer...
This year I NEED tuning, and hope to buy a Strange 9" with Slicks and Skinnies this summer HELLOOOOOOOOOO TRACTION!!!
PongoX11 is offline
Old 01-07-2004, 03:46 AM
  #100
TT-TECH Veteran
Inspector12's Avatar
For the year of 2004 I am hoping to get the Supercharger on the car and all the other suspention stuff I have on it too. I also watn to get the rest of my garage setup done. And I want $100 to help me do it.
Inspector12 is offline
