How about a Short Block GP
Originally Posted by Brian@AP-Engineering
"Strong" and "cheap" usually dont go hand in hand.
a 700 hp 408 will run 4870 .
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
ok...let me change that to "inexpensive"
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
What would the same motor cost with a stock crank. 4.03 iron block with stock crank and good enough pistons and rods to handle 700 rwhp on juice.
You can email me at alljonz@aol.com
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
PSJ Wannabe & Attention Whore
Originally Posted by Pewter'00Z28
On the 347 can you get it to about 14:1 compression for about the same price? ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Here is the short block pricing: 347 or 6.0 370 cheap street, 2500
382 or 6.0 408 stroker with callies crank , 4219
Thats 200 off the regular price. Who wants to step up to the plate ?
Thats 200 off the regular price. Who wants to step up to the plate ?![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ohh man...thats so kick ***. 6 liter 370 cubic inches for $2500...outstanding!
So is the 408 price.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#33
I have a turbo car also and would be doing the group purchase with Byardog. What would you charge for new heads nothing to big stage 1 or 2, upgraded valve terain, lifters, pushrods and rockers?
Kane
Kane
#35
At this time we will be shying away from Eagle cranks until they are a known good part. The eagle rods are known good and will be used. Second problem is supply of the eagle cranks. 850 for a crank that needs 400-600 for balancing makes you within 200-400 of a callies that will take a 1000 hp.
Slowverado- all depends on what pins and what rings you want to upgrade to.
#36
Brian what kind a deal can you swing for the following:
Kane
Kane
#39
For those going FI setup I will post some info that should help.
Trying to get to 8.5:1 CR is what the avarage FI person shoots for.
With a stock set of LS1 (66.67)heads and no milling with a 347 cubic inch motor you will need, Piston's with a -18 dish.
With 6.0 Liter heads (71.06) in a 347 you will need a -13.5 dish.
With LS6 heads (64.45) you will need a -20 dish in the pistons.
Going with a 370 cubic inch motor.
Stock LS1 heads -23 dish
Stock 6.0 (LQ9) heads -19 dish
Stock LS6 heads -25 dish
Using a 408 motor
Stock LS1 heads -34 dish
Stock LQ9 heads -29.5 dish
Stock LS6 heads -36 dish
This is using a .052" head gasket and no milling to the heads.
Hope I am correct and hope this helps when building your motor with APE.
Using a 408 motor
