Roll cage deal of the century!
What we are doing right now is a large production run of 8.50 legal 8 point chromoly and mild steel full roll cages. We will be doing the standard pre-bent cage and a complete pre-fit(not "jig notched") setup. The pre-fit setup is a 100% accurate fit, no hand tuning necessary. We are now CNC forming these cages! The 8.50 kit will have door bars bent for added shoulder and armrest clearance, and rear bars(over seat or no seat option) and laser cut floor plates. The a-pillar bars are designed to go through the dash at the intersection of the extension panel and the dash carrier. We will also supply a wire loop and chassis tab for harness attachment purpose. This kit with proper installation and welding technique will pass NHRA/IHRA certification with no problem.
Main structure in chromoly material is 1.625 x .083 tube, the shoulder bar and short diagonals are 1.25 x .065. The chromoly is high quality aircraft grade material, and only USA made.
The mild steel is high tolerance .120 wall DOM(drawn over mandrel) seamless material. This is no cheap and heavy .134 wall ERW tubing you commonly see in other "10 point" kits that are actually only 8 point.
The standard pre-bent only chromoly cage kit will run 525.00 plus a flat rate of 140.00 shipping in central US. The pre-bent only DOM seamless mild steel kit will run 350.00 plus 140.00 shipping. Far west states, southern FL and TX, and ME may require minimal freight surcharges.
The complete pre-fit chromoly cage kit will run 795.00 plus a flat rate of 140.00 residential or business shipping in central US. The pre-fit DOM seamless mild steel kit will run 610.00 plus 140.00 shipping. Far west states, southern FL and TX, and ME may require minimal freight surcharges.
We can make any of these combos available in 10 or 12 point. This addition will add extra rear X brace, a pair of engine bay bars, or both. 10 or 12 point will get you no extra certification level beyond the basic 8.50 kit, but will add rigidity to the chassis. The rear x-brace or bay bars will add 150.00 each set.
We also will have swing-out door bar kits(nice billet type for 125.00/ door) and preformed window net kits(100.00) available to compliment your build at great prices.
In order to get this group purchase done we will need a 50% deposit on all orders, and we need a minimum of 15 committed to offer these prices. If someone is interested in a multiple kit order we will be willing to work with you on a special freight quote.
Once we get to the 15 minimum mark we will give a guaranteed ship date, but the way things are going right now the pre-bent(not notched) kit will ship in approx 3 weeks, the notched kit will be 6 weeks. The sooner we get the 15 committed orders the sooner the kits will ship.
MWC is your F-body leader in suspensions, rearends and roll cages. The record holding 6 sc stock suspension cars of Ohio Boys Racing, Koolrayz, LASTLS1, Brian Black, Eddie Krawiec are just a few of the customers using MWC components. The results don't lie!
__________________
__________________
