Lingenfelter 346ci shortblocks $2,095.00!!
That's right, we are still offering the fully assembled shortblocks at this very low price, and they feature the following items:
LPE Blueprint & Professional Assembly
Includes verification to LPE specifications of the following items
• Cylinder bore diameter • Lifter bore diameter
• Cylinder wall taper • Piston skirt taper
• Piston diameter • Piston to wall clearance
• Deck height of block • Piston ring end gap
• Bearing clearances • Rod side clearance
• Crankshaft end play • Bolt torque specifications
Parts included in assembly:
• GM LS1 aluminum block, - 3.900" bore
• Water jacket plugs, oil galley & cam bearings
• Mahle forged aluminum pistons - coated
• Mahle moly file fit rings - 1.5mm, 1.5mm, 3.0mm
• GM LS1 crankshaft
• GM LS1 connecting rods
• Speed Pro heavy duty rod bearings
• Speed Pro heavy duty main bearings
Short block price as shown $2,095.00*
Short blocks in stock now and ready to ship.
* Plus core charge $800.00 - refundable after we receive and inspect your core.
You can see a full description and list of options here:
http://www.lingenfelter.com/ls1shortblock.asp
Please feel free to call or email me with any questions
Ed
• GM LS1 crankshaft
Ed
We use new GM connecting rods wich come with the latest rod bolts. These bolts are stronger than the original pre-'00 rod bolt, but not as strong as an A1 or an ARP bolt.
We can upgrade to a better rod bolt for the cost of the bolts(roughly $200.00 for A1)
We can also upgrade to a better rod which comes with the bolts, we normally use Manley pro series, which will add about 1300.00, but we are currently looking at other rods that can save some money without sacrificing any quality.
Ritchie, I'm not sure how long the price is good for, but a deposit will hold one for you at this price.
Please feel free to PM or e-mail me if I can answer any questions
Thanks,
Ed
Thanks,
Ed
