I need a GP on Morel Lifters..Any Sponsors????
Old 02-19-2005 | 11:10 PM
CAT3's Avatar
Restricted User
Default I need a GP on Morel Lifters..Any Sponsors????
Planning done, and build has begun, need some Morels now.
Charlie
Old 02-21-2005 | 12:15 AM
CAT3's Avatar
Restricted User
Ok, anyone have Morels in stock?
Old 02-21-2005 | 12:57 AM
Futral's Avatar
We have a set in stock let us know if you need them.
Old 02-21-2005 | 02:00 AM
CAT3's Avatar
Restricted User
sent PM.
Old 02-21-2005 | 06:15 PM
WICKED SS's Avatar
I am also interested in a set
Old 02-21-2005 | 09:11 PM
A3Z28's Avatar
i could definatly use a set of those also...solid roller is fun!!!
Old 02-21-2005 | 10:50 PM
CAT3's Avatar
Restricted User
Sent PM back, just need order info...kind of hard to call it stuck in Afghanistan. Thanks Allan.
Charlie
Old 02-22-2005 | 12:00 PM
curlyws6's Avatar
Any special pricing on Comp R lifters anywhere? I need some for my LT1.....
Old 02-23-2005 | 03:57 PM
WICKED SS's Avatar
any pricing?
Old 03-02-2005 | 01:19 AM
WICKED SS's Avatar
anyone else?
Old 03-02-2005 | 06:52 AM
curlyws6's Avatar
I'm in for a set of comp R's, maybe someone will do some sort of lifter GP on several brands. I have to get these in the very near future.... time for the cam install and tax returns are on the way!!
Old 03-06-2005 | 10:26 AM
Candy's Avatar
Originally Posted by WICKED SS
any pricing?
Morel solids or hydraulics?
Old 03-06-2005 | 04:13 PM
A3Z28's Avatar
Candy, can i get a price on Morel solids?
Old 03-08-2005 | 09:53 PM
racer7088's Avatar
Thumbs up
we usually have them in stock as well but it is hard to keep them.
Old 03-08-2005 | 10:33 PM
Loudmouth LS1's Avatar
Ok, so CAT3 was tellin me I should get the Morels instead of the comp R's, are they really that much better, what exactly is the diff, and are they worth the extra money (and how much are they anyway, I just heard like 2x the price of comp r's)?
Old 03-08-2005 | 11:45 PM
racer7088's Avatar
Thumbs up
Well the quality and the construction of the Morel is much superior to any other lifter but I do not know if you will see crazy power differences really but the reliability and quality are real. Some people do report turning more rpm and we had a 346 hydraulic roller make 500 RWHP and turn over 7000 with them FWIW.
The rollers are bigger and the axles are larger too and the oil bands are better for larger lobes as well on the hydraulic and solid roller models. I think on the hydraulic roller they are known to not pump down or up excessively so their oil control is very good which can add some more rpm and reliability to an engine which is never bad. On the solid rollers they are one of the ONLY real drop in LS1 lifters that work with larger lobes at all.
I sell the Comps and Comp Rs too and we use them a lot as well on our regular hydraulic roller builds.
Old 03-09-2005 | 12:29 AM
CAT3's Avatar
Restricted User
Everything Eric said above my reasons. My new cam is quite stout for a lil 347, 230's/240's enough over .600 on each side which is my daily driver and frequent flyer. So the Morels are POM, besides its what was recommended to me by the cam grinder, I think he knows his ****. The oil band improvements are an excellent step.
Old 03-09-2005 | 08:39 AM
Thanks guys, now I have some pros and cons to weigh out here to see if it is worth the tremendous increase in price over the r's!
Old 03-09-2005 | 08:49 AM
Camaroholic's Avatar
FWIW, it's not the lift that gets you with the oil bands, it's the base circle of the camshaft. My old cam and new cam have the exact same lift. My old cam (~1.4" base circle) worked fine with the Crane solid roller lifters. My new cam (~1.3" base circle) did not. Morels fixed that problem though.
Old 03-09-2005 | 09:19 AM
CAT3's Avatar
Restricted User
Cool, thnanks for the info Camaroholic. I thought I was reading some old posts where they discussed cams with high lift and duration having oiling issues. I really dont think 230/240's and somewhere b/w .625 and .650 is high lift or duration rather a decent sized daily driver street/strip cam....so evil!
Quick Reply: I need a GP on Morel Lifters..Any Sponsors????
