Jet-Hot Header GP
#42
Just wanted to let you guys know that the no air & egr headers are in production. There should be a GP in a couple of weeks. I'll post as soon as they're available.
We do have a guy lined up to provide dyno numbers as well. He did a run before taking off the factory manifolds and came up with 290HP. He's in process of setting up another run, but it will probably be a couple of weeks before we have the new & improved numbers.
Thanks guys!
Todd
Thanks guys!
Todd
#43
No AIR/EGR is what I need for an '02, correct? When will these be available? What else will I need other than the headers, and what comes with them? Thanks for any info you have.
#44
Nick,
'02's have air and no EGR. I bought the first set (98-99 which have both) and I bought a used set of air tubes(as '02 are different than 98-99) and an EGR block off plate.
The ones w/ no air and no air, require a 2002 owner to block off the air, or remove the air pump system. I think you will also get a code because your air pump will not function correctly. Unless you have LS1 edit or get a custom tune, it will keep you check engine light on and will not allow you to pass emmissions, which may or may not be a factor for you.
I think all the above is correct. If I'm wrong someone correct me.
