SLP and More Inventory Stock Liquidation Blowout!!
It's the DCV Tech Performance LOST-OUR-LEASE blowout! We've got to move all our product due to the loss of our lease. Below find products in stock and available for immediate shipment to you. Please e-mail us anytime at sales@dcvperformance.com to take advantage of these great once-in-a-lifetime deals.
NOTE: If you need further clarification on the SLP part numbers, for example, applications or descriptions, simply go to www.slponline.com for help and enter SLP part number.
Below, please find the deals in stock with regular and NOW special pricing (only while supplies last) - ALL PARTS ARE NEW:
Third Gen Camaro/Firebrd parts listed first:
AirFlow Research (AFR) Aluminum Heads loaded for L98 5.7L 87-92 Camaro/Firebird - NOW $1,999
TPIS Mini-RAM II with fuel rails and powdercoated red (looks like LT4 manifold) for L98 5.7L 87-92 Camaro/Firebird - NOW $1,299
*** NOTE: Above AFR heads and TPIS MiniRam II are open box items used for display purposes in shop only ***
Flowmaster 17228 American Thunder Exhaust for 87-92 DUAL Cat Camaro/Firebird 3" IN/dual 2.5" OUT - Reg $369 - NOW $329
Fourth Gen Camaro/Firebird parts in this section:
SLP 21044 - 98-99 Airbox Lid - Reg $99 - NOW $82
SLP 21045 - 00-02 Airlid - Reg $99 - NOW $82
SLP 23065 - Smooth Bellows 98-02 Camaro/Firebird - Reg $49 -NOW $39
SLP 30002 & 30024 - 82-92 1-5/8" DUAL cat W/AIR tubes headers and install kit - Reg $ 567 - NOW $389
SLP 30001C & 30022 - 82-92 Coated headers 1-3/4" ONE cat with AIR tubes and install kit - Reg $733 - NOW $623
SLP 30044 - Header install kit 96-97 LT1 for Loudmouth - Reg $29 - NOW $22
SLP 30045 - Loudmouth Install Kit for 93-95 LT1 - Reg $69 -NOW $52
SLP 30055 - Header install kit/crossbrace 98-02 Convertible - Reg $129 - NOW $99
SLP 30253 - Quad Exhaust Kit 98-02 with factory exhaust - Reg $299 - NOW $249
SLP 31011 - Exhaust System 95-97 LT1 2 cat "2 on the left"- Reg $399 -NOW $329
SLP 31033 - Y-Pipe larger diameter 93-95 1 cat LT1 - Reg $ 199 - NOW 162
SLP 31034 - Y-Pipe larger diameter 98-99 LS1 - Reg $199 - NOW $162
SLP 31039 - Loudmouth Dual/Dual 98-02 - Reg $349 - NOW $292
SLP 52466 - High Capacity Radiator - 98-99 LS1 - Reg $299 - NOW $249
SLP 70005A - Strut tower brace 93-02 V6 & 96-97 SS - Reg $99 - NOW $82
SLP 70401 - Panhard Bar 82-02 1LE with harder durometer bushings -Reg $39 - NOW $26
SLP 100209 - Alternator Pulley 94-95 LT1 - Reg $39 - NOW $25
SLP 100223 - Thermostat 160 degree LS1 97-02 Cam/Firebird & LS1 Corvette - Reg $55 - NOW $39
Stage 8 8911A Locking Header Bolts for LT1 3/8" x 1" long 16 count - Reg $29 - NOW $19
Taylor 74226 Spiro-Pro 8mm red spark plug wire kit 93-95 LT1 Camaro/Firebird - Reg $55 - NOW $35
Baer Eradispeed rotors for Camaro/Firebird and C5:
Baer 2301025 Eradispeed Front Pair 1 Piece 97-03 Corvette C5 - Reg $329 - NOW $274
*** NOTE: The above Eradispeeds are DIRECT REPLACEMENT systems - no mods reqd !! ***
*** NOTE: Eradispeeds are open-box systems we used for display purposes only ***
Tires and Guages here:
BF Goodrich g-Force TA/kd tires P315/35YR17 Left & Right (Grand Sport tires) BRAND NEW - Reg $599/pr - NOW $549/pr
<small>[ April 23, 2003, 12:03 AM: Message edited by: DCV Tech Performance ]</small>
