iROTORS Drilled Slotted Brake Rotors- IN STOCK W/ FREE S&H
Originally Posted by FRDnemesis
I'll be calling to order some tomorrow. Can I get cross drilled w/out the slots? I want them to match my front rotors that I already have.
Thanks,
Jeff
Thanks,
Jeff
Absolutely! We offer the rotors in drilled only, slotted only, or drilled/slotted. It'll take an additional 2-3 business days for the slotted only since we only stock the drilled/slotted.
Give us a call toll free at (888) 8-ROTORS if you have any further questions.
Thanks!
Originally Posted by tranzam01
how long is this sale going to last?
where in So Cal are you located?
We're in Norco. Off the 15 frwy at Sixth Street. Call us if you have any questions.
Thanks!
Are You All Still Doing The Brembo Blanks Drilled And Slotted With The Axxis Ulitmate Pads Is So How Much...? If Not What Is The Differences Between That Kit And The One You Are Offering In This Thread...?
Thanks,
John
Thanks,
John
ok ok, drilled is when they drill holes in the rotor while slotted is then they put slots in the rotor.. i dont kow exactly how the slot a rotor but im guessing with dome sort of router or blade.. the slots are usally lines cut into the contact path of the rotor from the lip to the hat (or cennter) of the rotor ovbiously the slots do not run all the way thru the rotor just deep enough to provide a channel for pad gasses and debris to escape the contact path while the brakes are engaged
i think drilling a rotor provides simlar benfits as slotting but when drilling a rotor the small holes are usally all the way thru the rotor.. some say this can lead to the rotors cracking prematurly..
Just to let you know guys, I have these rotors (drilled and slotted), and love them. I happen to find this company on ebay on day about 6-7 months ago. I bought them, and they were delivered on time. I didn't get around to putting them on for another 3-4 months. When I went to install them, I had already taken them out of the box and threw the box away (big mistake, as the box number tells you where they go on the car). I e-mailed them my problem and they replied back by that afternoon with an answer to my problem. I would definately do business with IRotors again.
