spool for a 10bolt
spool for a 10bolt
its come to my attention that there are a lot of problems often with aftermarket 12 bolts or even 9 inches still.. the 10 bolt is also a ton lighter, and more efficient.. tho weak.. with a rearend cover and some richmond gears ive personally seen two of them, one with 4.30's in a 6sp run a 1.4x 60ft and a 6.70 1/8th mile, and mine has lasted up to countless 150 shots off the line, tho it is an auto trans, the auto trans has broken twice off the line, while the 10bolt held!
outside of the t/a cover or an aftermarket 400$ posi unit i heard doens't help.. is there anyone willing to make a spool or something for a 10bolt. thing is i bet you'd have 10-15 orders right off the bat.. true this is still no good for ur 8 second 1/4 mile cars lol.. but for the bolton guys or even cam only guys looking to save a few pounds but still add some reliability i think this would be a hot item?!?! there are a few threads in the gear and axle section on this now.. if someone told me i could add 25% more strength to my 10 bolt for 700-1000$ id cut a check tommorow instead of investing in a 2000+ 12 bolt. some guys might not and i understand why.. but hopefully u see some of my reasoning..
any chance of this every happening as a cheaper better performance wise option other then the 12 bolt or 9 inch? lets face it.. prolly 80% of the members on this board still got there 10bolts... if only 10% were intrested and 3-5% willing to buy woudln't that make some money with as many ppl as there are?
thanks for reading.. just a suggestion, i do understand it still woudn't hold up like a 12 bolt ect... and im not trying to knock 12 bolts or those who have them
All the 7.5" 10 bolt mini spools I have seen are for 26 spline axles, not 28. I've heard that they tend to break on the street too since they are not nearly as strong as a full spool. More than likley that's why most are only reccomended for dirt track cars, I don't think that they ever really hook.
I've heard the Aurburn Pro, Eatons Posi, & Torsen T2Rs are about the strongest you can get for our 10 bolts. The T2R is really more for road racing though. My stock Zexel Torsen has taken some serious abuse and still looks new. I'd probrably look into the Eaton posi or possibly check out Detriot's new Tru Track if I needed a new one.
yea shoudl be good to go
ive been told not to buy a posi unit.. i heard there all pretty much **** and u will just lose anothr 400$ when it busts.. as far as the mini spool i was told this was a good idea by a well known dragracer.. however i dont thin he deals with many 10bolts in 02 camaros either.
Not much left for 7.5" 10 bolts. Torsen style posis with spider gears just break when they give up, and clutch styles like the Auburn and Eaton posis wear out. Eatons are rebuildable though, I'm not sure if Auburn makes their rebuild parts available to the public. With an M6 you'll probrably strip or break the ring and pinion before any good aftermarket posi breaks or wears out.
If you do find a spool or mini spool plan on replacing your axles too. I imagine the stockers will bend or break from normal street stress with a spool.
Speaking from experience, my friend had a mini spool and HATED it, he know has an auburn posi.even if you replace it with a posi or auburn have you still thought about the axles? my friend in his cam only TA 6spd broke his going into 2nd at the track and another one broke an axle once and the posi once. So plain and simple, get a 9in or 12bolt and go with it, you wont regret it. 10bolt=****! plain and simple
what exactly is the difference with a using a spool?
