Went to buy Crossovers they thought I was nuts...???
Ok its only Best Buy and I was being lazy (Although they did have an Alpine deck i like on sale for 150 the X200) but I went and said I need 2 Crossovers.
Now I am no Car Audio expert but I believe you use those when you want to keep one set of speakers getting say the Mid Freq Range and another set the High Freq Range. (Such as door panel mids and tweeters like I am working with).
The installer just gave me this look like I was nuts... then he showed me these things called Speaker Savers and they have 2 options 200hz, 300hz and 2800hz..... He hands me the 2800hz ones.... WTH are these things?
I was not sure I asked and he just could not answer for what I wanted to know. So I will ask you guys.
Here is my question:
WTH are these things? They look to me like inline cap to blow if it goes to high not a filter but maybe I am wrong.
If they are what I need do I need one on each side Pos and Neg? (I assume I do)
Thanks I am going to go start my speaker wiring and see where I end up.
Those are inline filters. they will only let frequencies above the rated level pass. not the most ideal but they will work. most places dotn sell crossovers alone, you would need to purchase a component set. And for future reference: stay away from bestbuy. unless you find the rare person who knows their stuff, they are terrible. i worked for circuit city for 6 years as car audiio install manager and i saw the same thing there that goes on at bestbuy. they have a few poeple who are awesome, but the idiots by far give them a bad name.
Well I guess for stock tweeters they will work then lol.
I have everything done but the drivers front (rewired that is), I am going to get the passenger side back on before I play with it.
Hopefully the radio has no further problems with powering off and on... I saw the BCM back there and I would pref not to have to mess with it.
Thank you for the answers, it will be nice to finally have a radio again that plays on all speakers. Now just to run a power and ground for the rear amp.
Hey since you did this for years maybe you can answer this for me.
On the Alpine AI-Net it has a Pink/White Interrupt wire that you have to ground to use the iPod on it. While its not as nice as the alpine that can control it that I just removed I like the 1.5Din size this one is.
Either way what I want to know is can I just put it in with the Main ground or does it need a body ground of its own?
i'd try amazon or ebay and actually get a crossover so you can adjust it the way you want. but be aware that crossovers are designed to split one signal to 2, a low and high (at least any one that i have seen). our cars from factory have separate wiring for tweeter and mid so unless you put in your own amp (which it sounds like you did but making sure),you will need a filter or something.
Ungrounded Moderator
i know many people that work at bestbuy. their workers are full of ****. the training is purely "read what box says". they just make up answers, unless that person happened to be a computer guru. hell, even most geek squad people dont know anything but how to run antivirus.
I was in that same situation, best buy doesnt know anything.
I went about it by searching online for all answers for about a week then decided to just disassemble the car and see what the deal was. By the way, for those that may not know, the factory amp was in the pass sail panel area. I have seen conflicting reports of it being in the spare tire wheel-well as well as behind the glove compartment. That could be the case for others, but as for my 94 base bird it was in the sail panel.
The total process took 4 hours to complete and that included the removal of all interior paneling, back seats, then re-wiring the back hatch speakers as well as the sail panel speakers with hiding the wire under the carpet. To me that was a lot easier than trying to mess with the factory amp and trying to splice wires to bypass it.
And The sound is so much better now!
I don't have anything fancy. Just replaced the two blown sail panel speakers with decent aftermarket ones, kept stock door and back hatch speakers for now. The highs sound great, but i don't have enough lows, so Ill be replacing the front soon enough with component speakers in the coming weeks then save up for a 10" sub in the back hatch area in that empty space across from the spare tire area.
I figured that while i was at it that I should scuff up, prime and paint my interior paneling. The stock color was tan, i am going with a Black and gray interior. I would estimate that an hour of the time working on this project was taken by the paint and prep work.
Also, while i was at it, i removed the felt stuff from the speaker covers on the sail paneling and painted that to match the black paint i used on the panel. It turned out really nice.
Did I mention that the sail panel speakers were subs? Replacing them with coaxial or whatever full-range speakers would be why your bass disappeared.
