5 Channel Amp
Old Nov 9, 2009 | 05:27 PM
98z8uup's Avatar
Default 5 Channel Amp
I was going with a 4 channel, but I think a 5 channel will work out a lot better. I need one that going to run all speakers and one 12 Kenwood (KFC-W3009) 800 watt 4ohm speaker.
Thanks
Old Nov 9, 2009 | 06:22 PM
Engine_HP's Avatar
how much power (rms) do u need for ur speakers ?
Old Nov 9, 2009 | 06:30 PM
pentavolvo's Avatar
the infinity 5ch is a great bang for the buck IMO
Old Nov 9, 2009 | 06:32 PM
jonyb's Avatar
I've got a Soundstream Van Gogh 800W 5-channel amp for sale if you're looking for used. I think it's 75x4 and 400x1. These were very powerful amps for their ratings.
Otherwise, Kicker makes a ZX700.5, but most of the Kicker's seem kind of weak for their ratings. I'm a dealer for Wet Sounds, and they've got a 1000W 6-channel in the lineup. Kinda pricey though.
Old Nov 9, 2009 | 06:35 PM
98z8uup's Avatar
I had a 4 channel Kenwood 640 watt. That I sold because it just didn't have the power needed. So something with a little more power than what I had.
Old Nov 10, 2009 | 12:25 AM
jonyb's Avatar
Kenwood's are very weak.... I pulled 3 of them out of my boat that came in it stock. The "1500 watt" amp that was replaced by the 1000w amp was no comparison.
Old Nov 10, 2009 | 06:38 AM
98z8uup's Avatar
What do you guys think about one of these:
http://cgi.ebay.com/KICKER-KX700-5-Z...item5d26e434d0
http://cgi.ebay.com/Rockford-Fosgate...item2ea9019154
http://cgi.ebay.com/SOUNDSTREAM-RUB5...item3ef6f16c3a
Old Nov 10, 2009 | 07:21 AM
jonyb's Avatar
That Rockford is probably a pretty good amp, but the other 2, not so much. The Rubicon series, and the KX series are both entry-level amps. Probably a good deal for that price range, but remember, you get what you pay for.
Old Nov 10, 2009 | 11:25 AM
bmnicolosi's Avatar
I like that kicker amp personally; but i would say either the kicker or rockford. Just be sure that you see the kicker is a refurb, the rf may be too because thats not even a current model. Look into these 5-channels also:
Infinity Reference 5350A
JBL GTO5355
Infinity KAPPA FIVE
Cadence FXA-5100
Polk Audio PA 1100.5
Alpine PDX-5
Memphis 16-MC5.1400
Memphis 16-MC5.700
Old Nov 10, 2009 | 01:59 PM
Engine_HP's Avatar
Originally Posted by bmnicolosi
look into these 5-channels also:
Cadence fxa-5100
alpine pdx-5
yap @@
Old Nov 10, 2009 | 03:27 PM
pentavolvo's Avatar
the kicker is a solid amp and puts out good power
Old Nov 10, 2009 | 04:41 PM
98z8uup's Avatar
Thanks guys, now I have to make up my mind now.
Old Nov 10, 2009 | 05:32 PM
98 LS1 SC's Avatar
I have the PDX-5 from Alpine. Great amp. Very small if you want to hide it. However it only puts out 300 Watts RMS to the sub. You may want a bit more for that 400 watt RMS Kenwood.
Old Nov 11, 2009 | 03:27 AM
cookba's Avatar
I have an Eclipse XA-5000. no issues for me.
Old Nov 11, 2009 | 05:07 PM
KEE AUDIO's Avatar
I have a monster Clif Design 5-channel amp that is about 2 feet long. It is 100W RMS x 4 @ 4ohms, 200W RMS X 4 @ 2ohms and the sub channel is 520W RMS @ 2ohms. I have 2 but I am keeping one for myself for my next project. Very underated amp, should push way more then advertised.
I also have several other 5-channel amps from Cadence, Powerbass, Boss (yea I know), Infinity, JBL, MTX, Blaupunkt, Crossfire, and Soundstream. I just picked up alot of these brands from a new distributor and would have to check availability but there are plenty of good 5-channel amps. Let me know if I can help and what kind of budget your looking at!!
Old Nov 11, 2009 | 05:29 PM
Engine_HP's Avatar
^^ what modle is the cliff design amp ???
Old Nov 11, 2009 | 07:12 PM
trx250r's Avatar
it will be kinda hard to find a 5 channel amp that will push 400wrms at 4 ohms. i might consider a different sub, either a dual 4 or 2 ohm depending on the amp you like. Or you might need to get a separate sub amp. 4 chan speaker amps are a dime a dozen and maybe a audiobahn a8000t or a8000v would be cheap power for the sub.
Old Nov 11, 2009 | 07:40 PM
98z8uup's Avatar
I will give you call on 11/12/09, because I need to pick up some more things from you.
Old Nov 11, 2009 | 10:03 PM
Transam1's Avatar
Memphis Belle i always though was the best 5ch amp as long as you get the class D one because the Sub channel is 1 ohm stable!!! good ****! other than that i like the rockford "T" series amps they have a 5 channel out there also...going cheep on amps = no power
Old Nov 12, 2009 | 12:07 AM
trx250r's Avatar
a watt is a watt doesnt matter how much it costs. usually multi channel amps are class A/B because they are a smaller design. a multi chan amp is just a bunch of smaller amps under one cover and class A/B amps are much smaller is why they use them.
