replacing factory speakers
I recently picked up a 2000 Z28 with a factory audio set-up that I am in the process of swapping out. The radio is gone and i have a new sony headunit with bluetooth now. Radio works great, speakers sound like trash. I'm well informed as far as speaker selection goes, but will I have to rewire each speaker from the head unit? I still have monsoon amp running the stocks, but not sure if I should use it for the new ones. HELP THANKS IN ADVANCE
subs give great bass and he can steer you in the right direction for door spekers
http://keeaudio.com/fbodyspeakers.html
You absolutely do not have to rewire anything just to replace door speakers. Also, the Monsoon amp is about the only audio component on the car that is worth a damn. It's not powerful but it works decently enough.
I've got 6.5" Polk Audio component speakers in my doors right now. Didn't have to rewire anything. Sound spectacular matched with a 10" subwoofer sitting in the hatch behind the rear seats.
I've changed the fronts to some Kenwoods, kept the sails, and put 4x6's in the rears, with a Xplode 12 on the hatch ledge, it sounds amazing. I want to get the kit from keeaudio though... The ones I have wired in the fronts aren't right... They pop/click at mid to high volumes if you wire them up to all of the stock wires. I just have highs up front, but I like it =)
I am also looking are replacing my stock speakers. I have read the sticky's but all the speakers recommend are not made anymore....
I was thinking about running Pioneer TS-A1782R speakers in the front as i read a review a member used the older model of these and liked them a lot, and the specs looked good on them. Wasn't sure what to use in the sail panels, or for the 4" speakers in the back.
Any advice on a good speakers for door and sail panels? I figured for the 4" ones I'd just find a cheap set.
