Onstar help with 08 Tahoe - disconnecting
Old 03-02-2011, 05:00 PM
pwrtrip75's Avatar
Default Onstar help with 08 Tahoe - disconnecting
What is the simplest method to disconnect onstar on a 08 tahoe??
Long story short, a friends relationship problem and the vehicle I think is in both names and he is stalking her using the tracking device on it, knows where she is, the times...etc.. She doesnt think onstar is enabled but i think it is.
Is there a fuse?
Old 03-02-2011, 05:17 PM
tripblackls1's Avatar
i would like to know as well i might be looking to buy a onstar equipped car and rather not have bigbrother looking over my shoulder
i have a feeling that is more complected than just a fuse considering that its connect to almost all of the controls of the vehicle i have a feeling its going to be a big pita
Old 03-02-2011, 06:16 PM
pwrtrip75's Avatar
I dont know. I looked at every fuse. I pulled all of the ones that said SEO on them, "Special Equipment Operation". No idea if it shut it off or not. Hopefully it shut it off and she doesnt get stalked anymore. lol.
Old 03-02-2011, 08:40 PM
Shutdown Theory's Avatar
theres a onstar box on your car...i know on the impala its on the rear trunk and if unplug the box its disabled
Old 03-02-2011, 08:49 PM
pentavolvo's Avatar
find box, unplug antenna. unplugging box could throw codes etc
Old 03-03-2011, 07:29 AM
Ungrounded Moderator
WhiteBird00's Avatar
Most GM full size SUVs have the OnStar box under the rear (second row) passenger seat.
But I would be worried about some other tracking system unless this stalker works for GM. You can't just keep calling OnStar and asking "where is my car?" - they're going to wonder what you're doing. And unlike some other systems, there is no online tracking available for consumer use. Even if there was, it wouldn't be available unless you were paying for a subscription and have the correct PIN number. So it's safe to assume that he is not tracking the vehicle using OnStar.
Old 03-03-2011, 07:42 AM
pwrtrip75's Avatar
Its actually something be bought and connects to the OBD II port and uploads the info on to his laptop. he told her last night. I seen the print out she had, it had detailed log of every where she must have shut the vehicle off at, addresses, times, average speed driven to and from.
Is there any quick way to disable the OBD II port temporarily so he cant access it?
Old 03-03-2011, 07:54 AM
The OBDII port is under the dash on the driver's side - just unplug whatever is plugged into it.
Old 03-03-2011, 10:04 AM
pentavolvo's Avatar
change the locks so he doesnt have access
Old 03-03-2011, 10:13 AM
safemode's Avatar
Take the device out. Goto a car rental place and rent a car for a few hours. Plug it in. Take it back and be done.
Quick Reply: Onstar help with 08 Tahoe - disconnecting
