Installed Viper Alarm...Need Help!!
right. i cut the starter wire and had the violet on the car side of the starter wire and the green going to the key side. I was not able to start my car with the key with that setup though. I had to connect the flex relay wires as well. Flex relay output wire (pink/white) hooked up to the car side of the starter wire with the violet wire and Flex relay input wire (pink/black) hooked up to the key side the starter wire with the green wire. With this setup i can now start the car with my key, however the setup does not kill the car if the alarm activates.
Don't know if you figured out the problem or not but I would read up here lots of good info.
Alarm Install Guide
Alarm Install Guide
