What is the most effective sound damping material?
For something cheap, effective and easy to use duct insulation is the way to go. It's also not very heavy. I like the aluminum backed thin foam from frost king best. I get it from lowes/home depot or amazon.
If you prefer stuff like dynamat there is a thinner version of that stuff you can find at lowes or home depot. There is also what's called q pads from auto body stores.
I used the stuff from Lowes called "Peel and Seal" and it is working very nicely at about 18 bucks a roll. People cautioned me against it because they said it would have a harsh tar smell on a hot day. Well, they were wrong then and wrong now. Before I installed it, I put a 1000 watt heat gun to it for nearly two minutes. No smell then and no smell now and it is sticking like glue.
For all of these, you do need a scrupulously clean floor for best adhesion and I clear coated mine to do it even better. I also used a very thick layer of "Lizard Skin" on top of my floor sheet metal and back wall under the clear coat. All in all, my EC is very quiet and I think I will use the Peel and Seal on my doors under my Legendary door panels - on back order until the third week of August!!!! ARRRGGGHHH!!!
Rick
Rick
I used dynamat on the floor of my car.I will be doing the doors and roof this summer.I like the stuff. When I do the doors i'm not going to cover the holes in the inter skin,but i'll be putting some mat on the inside of the outer skin of the doors,i think that'll help alot.
