Where and how to install satellite radio?
I recieved a sirius satellite radio for christmas. I went to go install it today with the antenna up on my dash in the middle, very close to the window. I put the reciever also in the middle on top of my dash right above my vents.
Problems: The damn 3M tape doesn't stick for **** on the antenna strip. Probably doesn't help that its 17 degrees out. Also it seems damn gaudy to have the reciever on top of the dash with all of these wires all over the place. How and where did you guys install the reciever, antenna, etc. The top of the dash seemed like the only place I could put the reciever.
BTW: Mine is the bigass NFL Reciever that can also fit in the boombox, hence my problem
please don't put the tuner on top of the dash.
you can tuck it under the seat, under the dash (under/behind the glove box), in the spare tire well, or in the driver rear tire well. also if you pull your sail panels off you could probably mount it behind one of them.
these are suggestions i don't know if there is enough room in all of these places. i am going to install mine tonight or tomorrow, i'll post where i put it.
ok i am thinkin of something different. i was think of the tuner that you connect to a sirius ready head unit, probably smaller and doesn't have a remote.
i'm not sure what your receiver looks like so i don't know what to tell you.
Ungrounded Moderator
There are special brackets available that allow you to mount the satellite radio to the right of the factory radio. Try here: http://www.myradiostore.us/mounts-br...fic-mount.html. (Yes, I know it's an XM site but the mounts use the same holes for Sirius radios.) Unfortunately, they are rather proud of what amounts to just a specially bent and drilled piece of metal - $30 - but there aren't a whole lot of options for places to mount on our dashes.
Copy & Paste Moderator
Check out this thread for mounting:
https://ls1tech.com/forums/wiring-stereo-electronics/248790-guys-xm.html
I hid my antenna in my Formula's hatch/wing. The reception there is better than inside the car. Pics are in that thread. There are also pics of how someone mounted their Sky-Fi which appears similar in size and shape to the Sirius unit you have.
