Clarion deck battery drain
I bought a Clarion touchscreen DXZ955 unit(used-my first mistake) and had it installed. Immediately after installation driving home I noticed that even with the car turned completely off leaving it, I could still here the hum of something electronic running. Well after a month or so, the battery problems started and I recently had to buy a new one. Turns out, as the stereo shop told me, the unit has a bad sauder joint in it somewhere and even with the car completely off, its still sending a small current to the factory amps(which they told me, were current sensitive, so turning the key off does no good). My question is, is there a fuse I can pull or some other method I can take until I can get another deck? Thanks for any help.
There should be a cpu unit under your carpet somewhere its about the size of a laptop all flip screens have them they dont work without... MABEY someone can crack that baby open and see if they could fix it but i dont think it can be done ....I had the same thing happen to my brand new kenwood touch flip they replaced it for free...good thing to cuz that bitch was 2k... Sounds to me like your focked unless theres a cross somewhere.
Ungrounded Moderator
Actually, pulling the RADIO fuse won't help because it is ignition controlled anyway. If the Monsoon amp is the source of the current draw then you can pull the RADIO ACCY fuse and nothing else will be affected. If the head unit is the problem then you can pull the PWR ACCY fuse which handles the HU memory, etc. but it also powers the hatch release, power mirrors, and alarm shock sensor.
