My alarm goes off when I open the door.
Everytime I lock my car, and I unlock it, and open the door, the alarm goes off. I have the fuse to the horn pulled out to avoid embarrassment. It's always done this, and I don't know why. Moving into Phoenix pretty soon, and would like to 1. have a horn to honk at mother F%&*ers that pull out in front of me, and 2. have a legitimate security alarm.
It stops when I put the key in the ignition, and turn it.
Anybody know what's going on?
Thanks a lot,
-Ronnie
Thanks a lot,
-Ronnie
That must be it, It probably had keyless entry before, and the dude lost the remote or something. I don't know why I didn't think of that.
Thanks man. I guess sometimes you just need an elbow to the side to make you think straight.
Ungrounded Moderator
You can buy replacement remotes on eBay and program to match the car. Programming instructions are in the owner's manual and posted in the FAQ sticky at the top of the forum.
Instead of disabling the horn you could have just programmed the alarm off. Alarm programming instructions are also in the owner's manual and posted in this thread.
[QUOTE=junkindatrunkmx6;8941221]Everytime I lock my car, and I unlock it, and open the door, the alarm goes off. I have the fuse to the horn pulled out to avoid embarrassment. It's always done this, and I don't know why. Moving into Phoenix pretty soon, and would like to 1. have a horn to honk at mother F%&*ers that pull out in front of me, and 2. have a legitimate security alarm.
Mine did the same thing..You have to go into programming mode to shut the alarm off or change the setting..But without the remote it will do it everytime you unlock the door by key..Its very easy to do.I just disabled mine..
you have to get the right remote tho have Gm look up you Last 8 vin digits and he can tell you which one will work. my transmitter went bad as well and i was having to lock it like that then open with key.. you have to unlock it then jump in and turn the key to Acc so it wonk honk.. if you unlock the pass side it will automaticlly go off right when you open the door
