Subthump stealth box and 8 gauge wire
Old 05-05-2008, 07:51 PM
JustinID's Avatar
Default Subthump stealth box and 8 gauge wire
Does anyone know if the hardware on the Subthump stealth box is large enough to handle 8 gauge wire? Yes... I know 8 gauge is huge overkill, but all I have laying around is 8, 16, and 18. I don't want to go buy any more speaker wire if the 8 gauge I have will fit.
Old 05-05-2008, 08:04 PM
shaun's Avatar
i doubt it will work with 8 aug wire. go to wallmart and they have some 12aug sub woofer wire in a kit for about 20.
Old 05-05-2008, 10:33 PM
JustinID's Avatar
Yeah, that's pretty much my backup plan.
Old 05-06-2008, 09:54 AM
pentavolvo's Avatar
how much power are u running 16ga is prly fine if its only a few feet
Old 05-06-2008, 10:54 AM
KEE AUDIO's Avatar
^^^Agreed, if it's a short run your not going to lose that much.
Old 05-06-2008, 01:20 PM
JustinID's Avatar
I've measured it to be about 5 feet from the amp to the box and then what ever extra foot or two is inside the box. I'll be running 800-900 watts RMS (but likely much lower than that most of the time as I don't want to rattle my car to pieces).
Old 05-06-2008, 01:25 PM
JustinID's Avatar
The idea that I should be running larger than 16ga comes from the bcae1.com website. I used one of his calculators for speaker wire and it shows 16 gauge as being too small. I put in 900 watts, 5 feet of wire, 16 gauge, and 2 ohms impedance. That gave 20.8 amps, 124 mils/amp, and a voltage drop of 0.83. The site recommends staying above 300 mils/amp and keeping a voltage drop of less than 0.5. Of course the decibel loss they're talking about with that voltage loss is only 0.17, far below what can be heard.
I guess my concern is about pushing 20+ amps through 16 gauge wire.
Old 05-06-2008, 03:59 PM
pentavolvo's Avatar
true 900 watts is alot personally id go pick up some 14ga or 12 at the hardware store. lamp cord will work fine as well
