Street Racing & Kill Stories Basic Technical Questions & Advice
Bolt-on SS vs 347 stroker GT
Old 10-25-2008, 01:48 AM
  #41
88blackgt's Avatar
RPMs are a huge factor when discussing the durability of a stock late-model 302 block; often more important than sheer power. and the girdles do nothing but keep everything in a nice pile when it breaks.
I'll be spinning my stocker to 7ish and we'll see how long it takes to make two inline 4s although I put in smaller pills.
Old 10-25-2008, 02:08 AM
  #42
BlackTTC6's Avatar
Originally Posted by Dynotune04
id build a 331 before i built a 347. the tend to be more peppy.
X3. If i was building a 302 based motor. My first mod would be a dart block
Old 10-25-2008, 08:03 AM
  #43
12sMustang's Avatar
A lot of ignorance to go around in this thread. Has anyone checked out the latest 5.0 mustang magazine? In it, a 340 c.i. engine with a boss block makes 600 hp n/a and 800 hp with nitrous.
To the ignorant GUY from strawberry, Alabama: I've got a 331 c.i. fox-body and I'd gladly take your $20 (or more) in any race against your car from a drag or a roll, if you're willing to come on down to Columbus, GA or Silver Dollar raceway in Reynolds. If you're confident enough in your POS then I'll make it worth your while.
To others: a properly built 347 will always make more power than a similarly built 331, and this is coming from a guy who built a 331. The problem with 347s has been greatly exaggerated and can even be easily overcome with a proper length rod 5.315" rod instead of a 5.400" rod. If you use this rod, then you can use the exact same piston in a 347 that would otherwise be in a 331. Even without the use of this length of rod, many builders have had absolutely 0 issues with a 5.400" rod and proper clearancing. Bottom line is that properly built there is no oil consumption problem or power reduction that will result from choosing a 347 c.i. engine instead of a 331. The increase in stroke is just 15 hundredths of an inch. Think about the mechanics of that. That's a crankshaft with throws that are offset only 75 thousandths of an inch more than the 331 crank.
The hype that resulted in this new myth that 331s make more power than 347s came from a DSS dipshit that had his opinion posted in a MM&FF magazine. It was dead wrong at the time and has always been dead wrong. I don't know if this was some kind of marketing hype or if he just saw a 331 with a better combo make more power than a 347 with worse combo and didn't put 2 and 2 together.
I made the choice to go with a 331 based on the deal I could get on a crank and rods that resulted in that displacement. That said, I'd swap in a heart beat if I could get a comparably stout 3.400" stroke crank with similarly tough 5.315" rods. I also needed a thicker piston (added compression-height) to help shield the wrist pins from the increased heat associated with a high-boost turbo application.
Chris
Old 10-25-2008, 03:49 PM
  #44
ls1passion's Avatar
Originally Posted by slowponystreetracer
Ha is that right? Well i got a 20 dollar bill in my billfold that says my ol white sdime will drag that peice of **** grandma cougar down the road.I havent lost to a junk *** ford yet , hell the peices of **** usually break down before we get a run..Wait ,i have lost to a ford falcon..but i guarundamntee ill put a white stripe on that cougar.My sdime will skin it back son. 20 dollars...get you some son , ill send his peice **** back home ona a gawddamn trailor.
fine im in fresno california and would love 4 u 2 come out. u could race the cougar then ill race ur junkie *** car. ill let u see how fast any car can be made. the one thing u tend 2 forget u fattard is that any car can be made fast.
so if ur man enough come down here and crush all our fords with ur rocket car
Old 10-25-2008, 05:23 PM
  #45
Tech Apprentice
Stopsign32v's Avatar
if i were to build another motor it would pull to at least 7.5k
So why couldn't you spin a 302 stroker to that rpms?
Old 10-25-2008, 06:07 PM
  #46
ponygt65's Avatar
Gotcha.
HAHAHA....wow. YOu are more of an idiot that one could assume.
So, genius...tell all of us what weight, power, et and TS your car is. I'm willing to bet you either a) won't/can't or b) will ie up uranus.
He couldnt' drive 10 minutes to race a stang, let alone 15 hours.
Old 10-25-2008, 07:17 PM
  #47
ls1passion's Avatar
Originally Posted by ponygt65
Gotcha.
me and blckz28 are getting ready 2 give ls1tech some badass vids here pretty soon. hopefully monday my **** gets fixed. if it does come 2 the meet with us ponygt65 so u could be the camara man
Old 10-25-2008, 08:25 PM
  #48
ponygt65's Avatar
That sounds cool man.....but I have my kids most of the time. Let me know when it is and I'll see if it's a day/time I can do it.
Old 10-25-2008, 08:40 PM
  #49
E$O3200's Avatar
A well built 347 is better than a 351W. IMO Rob's Automotive Machine in Hayward, CA has an N/A carbed 347 running 10.3 @133 on its first time out.
Old 10-25-2008, 08:42 PM
  #50
lemons12's Avatar
what did i tell you about letting other mustang swingers on this site pony.. i am highly disappointed..
Old 10-25-2008, 08:46 PM
  #51
E$O3200's Avatar
Im actually getting a 383 sbc built. Trying to look for a nova to put it in. So how am I a "mustang swinger" ???
Gotta respect fast cars though.
Old 10-25-2008, 08:48 PM
  #52
lemons12's Avatar
just messing with you and pony man!
Old 10-25-2008, 08:49 PM
  #53
E$O3200's Avatar
hahaha
aite then
Old 10-26-2008, 01:42 PM
  #54
88blackgt's Avatar
o god more 5.4 vs 5.315 bullshit
"but the wrist pin intersects the oil ring!!11!!11!zomg!"
Old 10-26-2008, 02:11 PM
  #55
Moderator
JayplaySS's Avatar
Guys, ease up on the insults. This is only the internet.
Old 10-26-2008, 04:14 PM
  #56
Tech Apprentice
Originally Posted by 88blackgt
RPMs and how well the rotating assembly is balanced play a huge factor when discussing the durability of a stock late-model 302 block; often more important than sheer power. and the girdles do nothing but keep everything in a nice pile when it breaks.
Modded it alittle for ya buddy.
I'll also be spinning my little 302 to 7.
Old 10-26-2008, 04:15 PM
  #57
Tech Apprentice
Um no, not even close.
Old 10-26-2008, 04:47 PM
  #58
butler's Avatar
my last toy was a 91 hatch with a chp street fighter 347 with trickflow 205 heads vic jr. street 750 hp carb 4.30 gear. Ran 11.02 @ 125 then put a 3.73 gear in it a 150 shot and ran 132.5 mph int he 1/4 @ kcir.
Old 10-26-2008, 08:53 PM
  #59
Dynotune04's Avatar
not saying you cant. i just wouldnt
Old 10-26-2008, 09:04 PM
  #60
Tech Apprentice
Reason?
