so I raced a ls1 tonight
#124
I think it is funny how you call everyone out saying you would run them but since they aren't local you won't go to a different track and run them...that is just saying that my **** might break and instead of being a man and running somewhere else...I am going to be an internet tough guy and stay local...then tell someone else if they trailer a car that they are a ***** for not driving it to the track...
#127
You're clueless. Race car? Does this sound like a race car to you?
A 600hp race car...now that's funny.
- Stock long block.
- Stock T-56 transmission.
- Stock exhaust manifolds (I don't even have headers!)
- Full interior.
- 17" wheels all the way around
#128
You forgot to mention some things on your car Unit!
2.2 kenne bell supercharger
bassani x pipe w cats
sd 55lbs injectors and jumpers
accufab polished big oval throttle body
billet flow 2.76 pulley
nitrous express wet kit
lfp heat exchanger
lakewood 50/50 shocks
eaton posi
dts 8.8 solid axle
strange 31 spline axles
3.90 gear Unit
This is some of the stuff on this race car! I challenge you to look on units f quick page and see what else this race car has.
lfp heat exchanger
eaton posi
dts 8.8 solid axle
3.90 gear Unit
#129
lfp heat exchanger
eaton posi
dts 8.8 solid axle
3.90 gear Unit
lfp heat exchanger
eaton posi
dts 8.8 solid axle
3.90 gear Unit
that the mods you listed above are NOT mods used in a race car.
#130
Let me rephrase this! Your fast street car! I'm not ignorant your car should be in the 10 second range with all that power and if you raced a milan they would kick you out cause you dont have a cage. But then again
#132
The fact remains you are the only one LOCAL calling me out. Your car is the fastest car in this particular thread with the exception of that ZR1. I have a simple h/c car and you have a highly modified livernois car. Wheres the challenge in that?
#133
anything after that so the ZR1 would walk away from me I'm sure after
140mph or so. I'd have to shift into 5th gear and 3.90's with a 26" tire
aren't going to cut it for that kind of race. That and aerodynamics are not
in my favor. BUT I'D STILL RUN THAT RACE...unlike someone here.
You're still not getting it. There is nothing "highly modified" about my
car. It's got bolt ons, a blower, and suspension. Everything else is stock
including the engine (heads too).
It's not about a "challenge" as you mentioned above. It's about you
running your mouth in every single thread yet you won't man up and
actually race...even though I said I'd spot you car lengths, I'd run on
7 cylinders, etc. Whatever, I'm done wasting my time. You'll never get
it.
#134
lfp heat exchanger
eaton posi
dts 8.8 solid axle
3.90 gear Unit
lfp heat exchanger
eaton posi
dts 8.8 solid axle
3.90 gear Unit
Under your rules, I guess you need to think of your car as a race car:
converter
gears
heads/cam
racing suspension
hmmm.. whos car sounds like more of a race car now?
#135
Only a simple h/c setup? After reading your posts, I thought you had like a 6sec turbo big block methanol car.
#136
Sounds like you've got yourself a racecar. Vroom vroom.
#137
hey man, watch out, 02 wife will talk all **** to you and even say he'd beat you in a race...............but your not local so itll never happen. so instead, he will resort to saying "how come you need a turbo to go fast and all i have is an all motor ls1"
#139
I considered banning 02 wife on general principle alone, but I didn't think that would be appropriate. Besides, it's better to let him stay here and to continue to let him make himself look foolish. I think he genuinely is interested in the LSx platform so he can stay even though his posts
come off as if he were a troll.
#140
