bolt on lt1 vs near stock m6 firehawk
#41
I do have the slip for the 7.9 but have yet to cut a 60' out of the 1.9s since then(it was a 1.76) but have run 8.2s@86.xx which is still 12.7-8 territory with 110.xx mph traps...
#42
ive trapped 86.xx several times guys im down to race any ls1 car with similar mods im in upstate, sc. But i wouldnt say its light bolt ons(to me light would be cai/catback)
My car has OEM style Ram Air Hood(with ls1 k&n FIPK), 160 stat, long tubes, 3" cutout(always open), 1.6 RRers, lt4 springs, tuned. I can drive well, its light and has 3.42s(good for hwy races) I dont get why its so hard to believe but im not here to appease you guys...
Thats a light bolt-on car. Post up your time slips.
#43
#46
#47
How far are you from outerbanks NC(Nagshead) 95 Z? My GF has a house there. I could bring the Z down. I don't mind driving 2-3 hours to race some guys
My 2 last run from this pass weekend at 75/80(hitting the limiter on the 2-3 shift-need to lower it... its a **** hole track too) so it should be a good run.
1.659
5.021
86.14
7.856
108.53
12.389
1.653
5.033
85.64
7.878
108.22
12.426
1.659
5.021
86.14
7.856
108.53
12.389
1.653
5.033
85.64
7.878
108.22
12.426
#50
no but it does weigh 3600 lbs with me in it. unless he is at sea level its just not gonna run 7.9 thats cam only ls1 territory. if he is running that with those mods and those slow *** 60' times he has the fastest lt1 ive ever seen, in real life and on the net. and hes not even full bolt on. come on, i can barely breathe becuase im up to my chin in BS.
#52
Especially to pull out a 7.9 with that 60'!
#53
His mph seems low doesn't it? I ran a 7.80 in my cam ls1 with hitting the limiter twice from 1-2 shift. Even then I trapped 90 with a 1.7 60'. Now for him to have almost the same 60 and 7 mph trap difference how would he only run a tenth off my time?
#54
I can definately believe he's a low 13 second car.. As long as he can drive the car.. But I'm just stuck on his amazing ability to pull up top soo hard... From 85 rolls.
#56
Does the op? With the times he's giving us, don't think so. No timeslip so nobody really knows.
Let's see him race someone
#57
Cam only LS1 territory in the 7.9's??? LOL, thats just funny. There is in fact guys that have dipped into the 9's with cam only setups and multiple cam only setups have been bottom 10's. Thats far less than a 7.9 in the eighth mile.
#58
If you can't breathe because of BS it's due to your own ignorance. The bolt'on LT1 record is in the 7.3x range. It was a 7.4x a year ago which was held by a guy here in Upstate SC named Shon Herron, and that was with a 6-speed car with 60' times in the 1.5x's. Do a search on that name and see what you find.
Boltons, cam, non gutted LS1's with sticky tires and decent suspension work are damned lucky to get into the 11's at any normal track.
#60
Venture outside the SRK section a little more genius. You will see that it is very REAL WORLD for cam only LS1's to go in the 10's and several in the 9's. If your cammed LS1 is still in the 12's with a tire, you need to buy a honda.
A full weight, stock suspension, mild/moderate cam only, stock gear, 6-speed, street tire LS1 must be what you're thinking of when you say "lucky to see 11's". Because full bolt'on LS1's have been running 11's for over a decade.
No Mike, I wasn't referring to my car.
