Tubaso Nitrous Trans Am Vs Machucando Turbo/Nitrous DSM
#41
http://houston-imports.com/forums/sh...=612251&page=4
some of this guys here are funny.
5w20 on that forum! can you tell mikerex that the owner of the $25k+ k25 hatch, search all my car make me take my nitrous jets, lines, and bottle off the car!!! my Team Runs Legit down here!!
#46
#47
[QUOTE=LVTubasoR;14796895]nop, i only race on the street for cash, i sometimes make exceptions and race my buddys for fun
$25k? Quit tooting your horn Ermis. You know damn well Livan is the poorest Cuban you know and he for sure doesnt have 25k to spend on a car. Your car alone was over $5K. His DSM was $600, and hes got maybe $5K into including the $150 junkyard stock trans. On top of that, 20 psi and a real rich base tune= 12s, maybe.
So your expensive build beat his cheapy one.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#50
Fuel on the fire:
A 25K build on a stock manifold, junkyard trans and $300 cams...lol
This car is accually not mine, but a car I work on. The guy who owns it and the Trans Am guy are "buddies" I guess. The Trans Am guy knew it wasnt leaving good and wasnt suppose to use nitrous right away. So much for a freindly race with no **** talk. This is not a real expensive build. Stock intake manifold, Turbonetics cast manifold, BC cams, stock auto trans.
#51
[QUOTE=TREVTEC;14809605] loll just the 4 brang new 555R and the turbo are worth more then my motor swap!! everyting on my car is use and cheap
home bolt ons not Trevtec Motor Sports fully built!! and my car was only $2500 ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
i have a $300 cam, an stock intake manifold, headers came with car, an $100 nitrous kit, $100 use injectors, stock tranny, stock rear end, stock long block, stock suspension, 300 buxs slicks/rims, and skinnys/rims cheap summit ones used, $50 summit nitrous window switch, and a $456 converter, all lavor me and my buddy! Beat Thatt TrevTec Motor Sportss!!! hahahhhaha
So your expensive build beat his cheapy one.![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#52
[QUOTE=LVTubasoR;14810926]
i have a $300 cam, an stock intake manifold, headers came with car, an $100 nitrous kit, $100 use injectors, stock tranny, stock rear end, stock long block, stock suspension, 300 buxs slicks/rims, and skinnys/rims cheap summit ones used, $50 summit nitrous window switch, and a $456 converter, all lavor me and my buddy! Beat Thatt TrevTec Motor Sportss!!! hahahhhaha We all know you paid $7500, and you are still making payments on that car, so, you failed already. Keep it up. Your rims and tires cost more too, he is running junkyard Eclipse wheels.
#53
[QUOTE=TREVTEC;14811065] hmmmmmmm i think you confusing me with someone alse!!! hmmmmm.... yea i think you are!....keepup the good work Trevor
#57
i member when u raced breeze.....
http://youtu.be/NlXqriyckZk
you should run him back with your new setup when he fixs his whip
#59
I've seen the parts list for this car on DSMtuners. It has:
-A stock (unported) head
-mediocre $300 cams
-stock intake manifold and throttle body (doesn't flow ****)
- a stock junkyard trans
-A Hughes converter that won't stall high enough for the car to leave in boost
- a 9:1 compression bottom end (not great for E85)
-a rich base map, boost levels in the basement, and i'm sure the timing curve hasn't been optimized yet either
Forget the various components the car should have. Give them some time to get a higher stall converter and a decent tune on the car and run it again.
#60
Dude, i'm not trying to pick a fight or be an ***, but cut the **** with this "fully built" $25k car stuff.
-mediocre $300 cams
-mediocre $300 cams
